Serial.println(8000*100); return 14464 ????
Hi! Probably it's look pretty stupid....but Subj.
tested on Uno. +,-, / and 8000*100 work fine...
  Serial.println(8000*10);
Probably you have any explanation of this paradox :)
Ops.... sorry....mistake in subject .... correct is: Serial.println(8000*10); return 14464 ????
Try a cast to unsigned long. 8000UL*10UL
You're using int math. THe largest value an int can hold is 65535. If you try to stuff 80000 in there you get 80000 - 65536 = 14464.
Use longs instead of ints as the last post suggested and your problem will be solved.
