Serial.println = Clear buffer?
Hi all,
Quick question that I couldn't find a definite answer to. Say hypothetically I have a arduino with a large code with lots of Serial.println's in the code as a debug. When I have a computer connected to the arduino, it will send the strings over serial as it should. So... My question is, If I have all these Serial.println's not serial.print's inside my code without a computer connected to the arduino. Does the arduino automatically clear out the buffer or does it start to accumulate and overflow the buffer?
I would assume it sends it out on the Serial line and forgets about it. aka clears the buffer. However I can't find any real documentation in my searches.
Any info / resources would be greatly appreciated. And I don't think a sample of code is necessary for this question but if so I could easily type something up.
  • Matt
It will clear the buffer because it will just send it. The Arduino has NO knowledge whatsoever if something is connected or not.
Serial.print() and Serial.println() both behave in the same way. The latter simply adds a linefeed to the output without it needing to be part of the explicit data printed. It does not, as the name might imply, print a line of data.
Depends on the microcontroller. You can bring a Leonardo (and probably a Micro) to a (near) grinding halt by disconnecting the USB cable (while it's powered from external power) and keep on printing.
An Uno is another story; being connected or not does not make a difference.
Thank you all for your answers.
  • Matt
@sterretje, true. I (wrongly) automatically assumed a "standard" Arduino like a Uno / Pro Mini / Nano / Mega etc. The ones without build in USB support which just use UART.
