Serial.println(F( giving error on RF24Mesh_Example_Master by TMRh20 [SOLVED]
Trying to understand why I'm getting an error and compiler exit on the following code by TMRh20:
/** Modification of RF24Mesh_Example_Master.ino by TMRh20 and RF24Mesh_Example_Master_Statics by TMRh20
 * This example sketch shows how to send data to nodes bassed on their ID.
 * The nodes can change physical or logical position in the network, and reconnect through different
 * routing nodes as required. The master node manages the address assignments for the individual nodes
 * in a manner similar to DHCP.
#include "RF24Network.h"
#include "RF24.h"
#include "RF24Mesh.h"
#include <SPI.h>
/***** Configure the chosen CE,CS pins *****/
RF24 radio(7,8);
RF24Network network(radio);
RF24Mesh mesh(radio,network);
struct payload_t {
  unsigned long ms;
  unsigned long counter;
uint32_t ctr=0;
  // Set the nodeID to 0 for the master node
  mesh.setNodeID(0);
  Serial.println(mesh.getNodeID());
  // Connect to the mesh
  mesh.begin();
uint32_t displayTimer = 0;
  // Call mesh.update to keep the network updated
  mesh.update();
  // In addition, keep the 'DHCP service' running on the master node so addresses will
  // be assigned to the sensor nodes
  mesh.DHCP();
  // Check for incoming data from the sensors
  if(network.available()){
    RF24NetworkHeader header;
    network.peek(header);
    Serial.print("Got ");
    uint32_t dat=0;
    switch(header.type){
      // Display the incoming millis() values from the sensor nodes
    case 'M':
      network.read(header,&dat,sizeof(dat));
      Serial.print(dat);
      Serial.print(" from RF24Network address 0");
      Serial.println(header.from_node, OCT);
    default:
      network.read(header,0,0);
      Serial.println(header.type);
  // Send each node a message every five seconds
  // Send a different message to node 1, containing another counter instead of millis()
  if(millis() - displayTimer > 5000){
    ctr++;
    for (int i = 0; i < mesh.addrListTop; i++) {
      payload_t payload = {millis(),ctr};
      if (mesh.addrList[i].nodeID == 1) {  //Searching for node one from address list
        payload = {ctr%3,ctr};
      RF24NetworkHeader header(mesh.addrList[i].address, OCT); //Constructing a header
      Serial.println( F(network.write(header, &payload, sizeof(payload)) == 1 ? "Send OK" : "Send Fail")); //Sending an message
    displayTimer = millis();
In other sketches Serial.println(F()) seems to work fine, so why not here?
Is this something I can fix without leaving out the F() wrapper, which I believe to be very useful?
The errors I get are:
C:...\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino/WString.h:38:74: error: array must be initialized with a brace-enclosed initializer
#define F(string_literal) (reinterpret_cast<const __FlashStringHelper *>(PSTR(string_literal)))
C:...\Arduino\libraries\RF24Mesh\examples\RF24Mesh_Example_Master_To_Nodes\RF24Mesh_Example_Master_To_Nodes.ino:87:23: note: in expansion of macro 'F'
exit status 1
Error compiling for board Arduino/Genuino Uno.
No, you can't use F(). It's only for string literals,
Ah - so the example code is faulty. That caught me off guard!
Thanks for the response.
      Serial.println( ... ? F("Send OK") : F("Send Fail"));
Yes - I see the methodology now @oqibidipo.
Thank you.
SOLVED
