Serial.println(millis());
uncommenting these lines to the program causes a comple error
#include "LedControl.h"
/* pin 12 is connected to the DataIn
   pin 11 is connected to the CLK
   pin 10 is connected to CS / LOAD
   We have only a single MAX72XX.
LedControl lc = LedControl(12, 11, 10, 2);
unsigned long outputs[9] = {0, 0, 0, 0, 0, 0, 0, 0, 0}; // 9 valuies output[0-8]
int a = 0;
  Serial.begin(250000);
  // Initialize the MAX7219 device
  lc.shutdown(0, false); // Enable display
  lc.setIntensity(0, 5); // Set brightness level (0 is min, 15 is max)
  lc.clearDisplay(0); // Clear display register
  outputs[0] =  millis();
  // Serial.println ( millis() ) ;
  for ( int a = 0 ; a < 8 ; a++ ) {
    outputs[a + 1] = outputs[a] / 10 ;
    outputs[a] = outputs[a] - (outputs [a + 1] * 10);
  // Serial.println( millis() );
    lc.setDigit(0, a , outputs[a]  , false);
any help is greatly appriceiated
thanks in advance
What error
Mark
collect2.exe: error: ld returned 5 exit status
Using library LedControl at version 1.0.6 in folder: arduino\ProgramsT\libraries\LedControl
exit status 1
Error compiling for board Arduino/Genuino Uno.
ffejrxx:
search youtube for the solution to that error
It's not a code error, it's a system related matter, try stopping ur real time protection(Anti virus).. "which is not recommended" or overwriting the ld.exe file to the bin folder in arduino folder.
As @BulldogLowell suggested Youtube is the answer. :slight_smile:
This is supposed to be fixed in the latest versions of the IDE. If you're running something before 1.8, try upgrading.
If you're running 1.8.2 and still experiencing the error, let us know...
fixed, thanks
was using 1.6.8
updated to 1.8.2, error is now gone
