I was just working my way through understanding an example sketch from the Adafruit_VL53L0X library and came across Serial.println() with no value assigned. This can be found in the body of the if statement in the loop function.
/* This example shows how to take
range measurements with the VL53L0X and display on a SSD1306 OLED.
The range readings are in units of mm. */
#include <Wire.h>
#include "Adafruit_VL53L0X.h"
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
Adafruit_SSD1306 display = Adafruit_SSD1306();
Adafruit_VL53L0X lox = Adafruit_VL53L0X();
#if (SSD1306_LCDHEIGHT != 32)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3C (for the 128x32)
// init done
display.display();
Wire.begin();
if (!lox.begin()) {
Serial.println(F("Failed to boot VL53L0X"));
while(1);
// text display big!
display.setTextSize(4);
display.setTextColor(WHITE);
VL53L0X_RangingMeasurementData_t measure;
lox.rangingTest(&measure, false); // pass in 'true' to get debug data printout!
if (measure.RangeStatus != 4) { // phase failures have incorrect data
display.clearDisplay();
display.setCursor(0,0);
display.print(measure.RangeMilliMeter);
display.print("mm");
display.display();
delay(50);
display.display();
return;
Is it purely there so you can add what you like, or is there another purpose for this empty function that I don't know of?
Thanks
