Serial.println once in i++ or i--
Hello, I am having a hard time trying to figure out how to Serial.println only once and only the latest increment or decrement.
decrement
buttonState = digitalRead(button);
  if (buttonState == 1 && pulse > 0 && userBalance) {
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("Dispensing Coins");
    for (int i = pulse * 2; i > 0; i--) {
      digitalWrite(relayPin, LOW);  // turn on relay - active LOW.
      lcd.setCursor(0, 1);
      lcd.print("       ");
      lcd.print(i);
      Serial.println(i); // i need to print only 1 since im going to send this to nodemcu and nodemcu to database
      // Check coin hopper sensor status
      if (digitalRead(coinHopper) == LOW) {
        // Coin detected, decrease pulse count and delay before next dispensing
        pulse--;
        delay(255); // Adjust delay as needed
        i++; // Skip this iteration // No coin detected, wait for coin
        delay(30); // Adjust delay as needed
increment
coinSlotStatus = digitalRead(coinSlot);
  delay(30);
  if (coinSlotStatus == 0) {
    userBalance = true;
    lcd.print("Press a Button  ");
    pulse += 1;
    sprintf(lcdBuffer, "Bal Php: %d0.00", pulse);
    lcd.print(lcdBuffer);
    delay(30);
    Serial.println(pulse); // i need to print only 1 since im going to send this to nodemcu and nodemcu to database
move your printing outside the for loop
i already solve the decrement code, but the increment, i cant get the exact serial.println. always ended up with 1 as result of serial.println which is it only reads the first print and not the latest print.
I inserted a 20 bill = 2 pulse
but the code prints only 1 and its the first serial.println and not the latest serial.println.
boolean pulsePrinted = false; // Flag for pulse print status
  delay(30);
    userBalance = true;
    pulse += 1;
    delay(30);
    if (!pulsePrinted) { // Print pulse only once when a coin is inserted
      pulsePrinted = true;
The advice is the same as previous. To print only the last value you have to place the print statement OUTSIDE the value changing loop code.
For the increment, move this lines outside the if (coinSlotStatus == 0) block
here's my full code, pls help me
#include <Wire.h>
#include <SoftwareSerial.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
#define button 4
#define relayPin 7
#define coinHopper 2
#define coinSlot 3
int coinSlotStatus;
int pulse;
int buttonState;
boolean userBalance = false;
boolean noCoin = false;
boolean iPrinted = false; // Flag for i print status
char lcdBuffer[16];
  lcd.init();
  lcd.backlight();
  lcd.clear();
  pinMode(coinSlot, INPUT_PULLUP);
  pinMode(coinHopper, INPUT_PULLUP);
  pinMode(button, OUTPUT);
  pinMode(relayPin, OUTPUT); // Set the relay pin as output
  digitalWrite(relayPin, HIGH); // Initially turn off the relay
  int first_i = -1; // Variable to store the first value of i
  if (!noCoin) {
    noCoin = true;
    lcd.print("INSERT BILL/COIN");
    Serial.println("Inserted Bill/Coin");
    lcd.clear();
      if (first_i == -1) { // Store the first value of i
        first_i = i;
        Serial.println(first_i); // Print the first value of i
      lcd.print("       ");
      lcd.print(i);
        pulse--;
    digitalWrite(relayPin, HIGH);  // turn off relay - active HIGH.
    pulse = 0;
    noCoin = false;
    lcd.print(" Thank You, Bye ");
    lcd.print("Pls get ur Coins");
    delay(3000);
    lcd.clear();
  delay(30);
    userBalance = true;
    pulse += 1;
    delay(30);
    userBalance = true;
    pulse += 1;
    delay(30);
i tried this earlier, i got 0 in serial.println
try this
Add at the start of the code
    userBalance = true;
    pulse += 1;
    delay(30);
this is the result
20:24:55.981 -> Inserted Bill/Coin
20:25:01.852 -> 1
20:25:02.003 -> 2
it does print but, did not exclude the first print
Ok, let see from the other side. How in your code you can determine when the pulse value ends changing?
