Hi folks,
I'm using a Pro Mini with a 3.3V ATMega328 and I'm trying to merge two pieces of code. Each of the two pieces of code works perfectly when executed independently.
The first part uses the Low Power library to put the ATMega328 into Power Down mode for 8 seconds - or multiples of 8 seconds (from http://www.rocketscream.com/blog/2011/07/04/lightweight-low-power-arduino-library/)
The second part is the secret voltmeter to measure the voltage of Vcc (from Google Code Archive - Long-term storage for Google Code Project Hosting.). This code measures Vcc and then outputs it to the serial monitor.
So, I'm trying to combine the two to periodically measure Vcc, and sleep between measurements for a fixed period.
However, when the two pieces of code are combined, the serial monitor shows garbled/erroneous characters. I've put in a line of code that returns three characters ("ABC") but these are garbled too.
Does something happen to the serial port during Power Down or wake-up that will cause it to malfunction... does it have to be reinitialised after wake-up?
The code is below.
I'd appreciate any help to get this working.
Thanks,
Andy.
// **** INCLUDES *****
#include "LowPower.h"
// Declare Global Variables Here
int Counter = 1; // to count multiples of 8sec power down period
long readVcc() {
long result;
// Read 1.1V reference against AVcc
ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
delay(2); // Wait for Vref to settle
ADCSRA |= _BV(ADSC); // Convert
while (bit_is_set(ADCSRA,ADSC));
result = ADCL;
result |= ADCH<<8;
result = 1126400L / result; // Back-calculate AVcc in mV
return result;
pinMode(LED_BUILTIN, OUTPUT);
// Enter power down state for 8 s with ADC and BOD module disabled
LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
if (Counter >= 1) // check if counter is at required number
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
Serial.println( readVcc(), DEC ); // send the measured value of Vcc to serial monitor
Serial.println( "abc" );
Counter = 1; // reset counter to 1
Counter++; // increment counter
