Hi All,
I'm looking to use Serial.println() to send the data from a rotating mouse wheel to the computer where I can save it. It works 99% of the time, but every now and then it will miss a decimal point, causing the data to spike up 100 fold. The microcontroller seems to be reading everything fine, but just forgets to put the decimal point in the right spot. I don't want to filter through hundreds of thousands of data points looking for and fixing the spikes.
Is this a problem with my code, a variable type, or with my arduino nano?
The function that prints out the data is at the bottom and called screen()
Thanks in advance!
JJ
#include <Servo.h>
#include <Arduino.h>
#include <U8g2lib.h>
#include <U8x8lib.h>
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
//THIS IS ALL THAT NEEDS TO BE CHANGED/////////
float lockedPeriod = .001; ///// time after startup for which the wheel will stay locked - enter in hours
float unlockPeriod = 24; ////time the wheel will stay unlocked for - enter in hours
int lockedpos = 120; //servo position to lock
int openpos = 100; //servo position to unlock
Servo myservo; // servo
int hallsensor = 2; //hall sensor pin
volatile long count; //rotation count
U8X8_SSD1306_128X64_NONAME_SW_I2C u8x8(A5, A4);
enum states
lock,
unlock,
relocked
byte currentState;
float stateStartTime;
float statePeriod;
unsigned long currentTime;
unsigned long printTime;
unsigned long relockedPeriod;
Serial.begin(57600);
while (!Serial);
currentState = lock;
stateStartTime = millis();
count = 0;
u8x8.begin();
u8x8.setFlipMode(1);
u8x8.setFont(u8x8_font_amstrad_cpc_extended_r);
u8x8.setInverseFont(1);
u8x8.setCursor(1, 0);
u8x8.print("current status");
u8x8.setCursor(1, 3);
u8x8.print("distance (m)");
u8x8.setCursor(1, 6);
u8x8.print("time (min)");
u8x8.setInverseFont(0);
u8x8.setCursor(1, 1);
u8x8.print("locked");
attachInterrupt(digitalPinToInterrupt(hallsensor), sensor, FALLING); //attach interrupt
pinMode(hallsensor, INPUT); //setup hall sensor
myservo.attach(9); //setup pin for servo
myservo.write(lockedpos); //default state is locked
statePeriod = (lockedPeriod * 1000 * 60 * 60);
currentTime = millis();
switch (currentState)
case lock:
if (currentTime - stateStartTime > statePeriod)
myservo.write(openpos); //open servo when condition reached
stateStartTime = currentTime;
statePeriod = (unlockPeriod * 1000 * 60 * 60); //converting to hours
currentState = unlock;
u8x8.clearLine(1);
u8x8.print("unlocked"); //update screen
case unlock:
myservo.write(lockedpos); //relocking the wheel
statePeriod = relockedPeriod;
currentState = relocked;
u8x8.clearLine(1);
u8x8.print("locked"); //update screen
screen();
void sensor () { //interrupt to measure rotations
count++; //every time hall effect sensor goes off, add 1 to count
void screen () { //function to update screen and serial monitor
Serial.println(float(count * .054 * 2 * 3.14));
u8x8.setCursor(1, 4);
u8x8.print(count * .054 * 2 * 3.14); //distance in meters (2 * pi * r)
printTime = millis() / 1000 / 60 ; //time in minutes since power on
u8x8.setCursor(1, 7);
u8x8.print(printTime); //printing time
