Serial problem
I am having some problems with my code. For now this only turns LED’s on and off but later I would like this to control my smart room.
So here is the problem. I am using a potenciometer to control what is displayed on LCD (some kind of a menu), and a button to accept that. No problem while I am sending data to computer using serial.println. But if I comment that line out - the potenciometer no longer works like it should. I turn it and the display doesn’t change. Only after i press the button the screen changes - or not.
The code:
#include <LCD4Bit.h>
#define LED 3
#define gumb 4
#define LED2 13
LCD4Bit lcd = LCD4Bit(2); //Ustvari nov zaslon z dvema vrsticama
int vrednost = 0;
int vrednostNaOpcijo = 1023/4;
int prejsnja_vrednost = 0;
int gumbek = 0;
int prizganaLED = 0;
int izbrana_opcija = 0;
int prizgan_zvok = 0;
  lcd.init();
  pinMode(LED, OUTPUT);
  pinMode(gumb, INPUT);
  pinMode(LED2, OUTPUT);
void prikazimeni(int opcija)
  lcd.clear();
    switch (opcija)
      case 1: lcd.printIn("Ugasni LED"); break;
      case 2: lcd.printIn("Prizgi LED"); break;
      case 3: lcd.printIn("Prizgi zvok"); break;
      case 4: lcd.printIn("Izklopi zvok"); break;
void domov()
  vrednost = analogRead(5);
  Serial.println(vrednost);
  if ((prejsnja_vrednost != vrednost) && (prejsnja_vrednost != vrednost+1) && (prejsnja_vrednost != vrednost-1) && (prejsnja_vrednost != vrednost+2) && (prejsnja_vrednost != vrednost-2))
    if (vrednost <= 255)
        izbrana_opcija = 1;
        prikazimeni(1);
    else if (vrednost <= 510)
        izbrana_opcija = 2;
        prikazimeni(2);
    else if (vrednost <= 765)
        izbrana_opcija = 3;
        prikazimeni(3);
    else if (vrednost <= 1023)
        izbrana_opcija = 4;
        prikazimeni(4);
  if (izbrana_opcija == 2)
      gumbek = digitalRead(gumb);
      if (gumbek == 1)
          prizganaLED = 1;
  else if (izbrana_opcija == 1)
      if (gumbek == 1)
          prizganaLED = 0;
  else if (izbrana_opcija == 3)
      if (gumbek == 1)
          prizgan_zvok = 1;
  else if (izbrana_opcija == 4)
      if (gumbek == 1)
          prizgan_zvok = 0;
  if (prizganaLED == 1)
      digitalWrite(LED, HIGH);
      digitalWrite(LED, LOW);
  if (prizgan_zvok == 1)
      digitalWrite(LED2,HIGH);
      digitalWrite(LED2, LOW);
  prejsnja_vrednost = vrednost;
So the problem is in Serial.println(vrednost); ← If I delete that the thing stops working. Why?
I'm a newby, so might be wrong. I think the problem is you are setting previous_value = vrednost every time, not in the if (previous != current....) statement. So if there is no slowdown of the code (caused by the println), the value gets reset too fast for the code to ever pick up the change.
You are correct! I am an idiot! Or maybe not - I just don't have any experience with microcontrollers or arduino. I just got it yesterday and I am still getting used to it.
EDIT: We are both wrong! It isn't working. I just added a piece of code that sent some data using serial port and forgot about it. When I removed that the thing stopped working.
