serial problem
Hi
I'm new to Arduino.
I have tried running the Graph example but keep getting the following error:
error: 'import' does not name a type In function 'void setup()':
In function 'void draw()':
In function 'void serialEvent(int)':
At global scope:
And highlights the following in the code
import processing.serial.*;
Thanks
James
Were you trying to run the Processing code on the Arduino? The code beginning with the line
is intended to be run on the Arduino's serial partner, not on the Arduino itself.
M
