Serial Problems
Hello, I am not very good at C programming so I need some help. :~ I am trying to create a program so when you enter 1 it turns on an led, but when you enter 0 it turns it off. I got it working to where when you type 1 it turns on, but when you enter 0 it still stays on.
int led = 13;
  pinMode(led, OUTPUT);
 void loop(){
   if (Serial.available()){
   int ser = Serial.read();
   if (ser = 1){
     digitalWrite(led, HIGH);
   if (ser = 0){
      digitalWrite(led, LOW);
The comparison operator in C/C++ is not "=" it is "==".
You also will have a problem because when testing for the character 1 it is not the same as the integer 1.
You should use:
if (ser == '1') {
and do the same when testing for the zero.
Pete
I tried it and it works! Thanks Pete!
Something similar.
// zoomkat 8-6-10 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
int ledPin = 13;
String readString;
  pinMode(ledPin, OUTPUT);
  Serial.println("serial on/off test 0021"); // so I can keep track
  while (Serial.available()) {
    delay(3);
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    if (readString == "on")
      digitalWrite(ledPin, HIGH);
    if (readString == "off")
      digitalWrite(ledPin, LOW);
    readString="";
