Serial problems
Hello,
I think i have a serial command problem over the TX pin.
When I use this Sketch and I press the button I get really strange outputs on my serial screan.
int ledPin = 13; // choose the pin for the LED
int inputPin = 2; // choose the input pin (for a pushbutton)
int val = 0; // variable for reading the pin status
pinMode(ledPin, OUTPUT); // declare LED as output
digitalWrite(inputPin, HIGH);
pinMode(inputPin, INPUT); // declare pushbutton as input
void loop(){
val = digitalRead(inputPin); // read input value
if (val == LOW) { // check if the input is HIGH
digitalWrite(ledPin, LOW); // turn LED OFF
Serial.println(“test”);
digitalWrite(ledPin, HIGH); // turn LED ON
¼?b??b?îb??b??
??"??b¿?b¼?b??b?îb??b??
??b??b¾?b??b?ïb??b??
??b¤?b?÷1¿åb??b??
??b??b´?b?îb?åb??1¿?
??b¾?b??b?ïb??b??
??b¼?b??b?íb?? ??b??b´?b?îb?Åb??
??b¿?b??b??b?åb??
??b??b¼?b¤?b?ïb?íb?Åb??1¿?
??b??b¼?b??b??
??b¿?b¼?b??b??b?ïb?åb??
??b??b´?b??b?îb?åb??b??
??b??b¾?b¤?b??b?åb??1¿?
??b¾?b??b?åb??1¿?
??b??b¼?b??b?íb??
??b??b¾?b´?b??b?ïb??1¿?"??b¿?b´?b??b?ïb?Åb??b??
??b¿?b¼?b?? ??
??b¿?b??b?íb?Åb??
??b??b´?b?îb?åb??b?? ??
??b¿?b´?b
What’s the problem here.
Thanks in advance.
RonaldB
Sorry it works, I burned a Lilypad code on a Diecimila board :frowning:
I was just going to suggest that it's a baud rate problem, but you've confirmed it. The different clock speeds of the two boards would account for the behaviour in the serial monitor.
