Serial programming and php
Hey Arduino people.
Im doing a big project in my home, and need to control some servos, from my php work.
How do i do that? Im using a php_serial.class.php
And are not sure how to use it.
Btw.. Could not post the code here, it's to long.
You don't know how to use the php class to send data to/receive data from the Arduino or don't know how to make the Arduino receive data from the PC/send data to the PC?
Can you post it as an attachment?
this is the attachment
i’ve also included the pde file…
php_serial.class.php (12.3 KB)
virkerdet.php (2.84 KB)
SerialLEDComm.pde (1.46 KB)
Opening the serial port when a button is pressed, and closing it, are both actions that are going to reset the Arduino. The LED will be on for less time than it takes for your eye to recognize that.
You need more buttons, with different actions. You need a connect button, that will open and configure the serial port.
You need a disconnect button to close the serial port.
In the other button callback blocks, don't open or close the serial port.
Hey Paul.
Thanks for reply.
Can you code PHP? If yes, a little code would be greath :-) Cause im not sure i understand what you ment.
Thanks again
