Though using a MicroView, so far the basics are just like the Uno. But mentioned anyway.
I have a serial connection functioning with characters (like words) but unable to see why the data is different to what's being sent.
I've tried copying many other serial scripts with this one being the closest yet to working. The MicroView has a temperature sensor and I need to send this information to the Uno.
The sender has a temperature sensor, so I'm simulating the 18.50 here.
Sender code:
// Begin the Serial at 9600 Baud
Serial.println(18.50);
Receiver code:
int incomingByte = 0; // for incoming serial data
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
// send data only when you receive data:
if (Serial.available() > 0) {
// read the incoming byte:
incomingByte = Serial.read();
// say what you got:
Serial.print("I received: ");
Serial.println(incomingByte, 5);
If I wanted to send and receive a float as accurately as possible, I'd use Serial write to send all four bytes of the float value as binary, but that throws up all kinds of synchronisation issues.
Tell us what you want to do, not how you think it should be done.
(I2C at 100kHz will be faster than serial at 9.6kHz)
Sorry mate, I guess I was trying to have a go before I just posted the desired outcome and look like I wanted it all done for me.
I want to collect data from a LM35DZ temperature sensor using a MicroView and transmit it to an Uno.
Once the Uno can see it, I plan to data log it. But just needed help getting it from the MicroView.
Here's my working sensor code, I had planned to then add in working serial program afterwards and exchange the temperature value into the fixed number location somehow.
Maybe Serial Input Basics - updated might give you some ideas; it describes options for the receiver side of the communication. You can test it with e.g. serial monitor.
Example 2 will basically be a match for your sender code although example 3 might be better after you have adjusted the sender. One of the examples shows how to convert from ascii to float using atof.
I've managed to make some progress. But if the Serial is used for anything other than the data, the output gets ruined.
I also only need the last four digits, but if I can't use the serial for anything else, I'm thinking maybe my MicroView i2c is damaged.
So far this is my closest shot to the answer....
Sender Code
#include <MicroView.h>
#define LM35Pin 0
float Temperature;
int value = 180;
analogReference(INTERNAL);
uView.begin(); // start MicroView
uView.clear(PAGE); // clear page
uView.print("Grrrrrr"); // display HelloWorld
uView.display();
Temperature = analogRead(LM35Pin) / 9.31;
Serial.print("Current temperature (oC): ");
//Serial.println(Temperature);
Serial.print(Temperature,5);
value = Temperature * 100;
Serial.write(value / 256);
Serial.write(value % 256);
delay(500); // Allows all serial sent to be received together
uView.display();
uView.setFontType(0);
uView.setCursor(0,0);
uView.println("Temp:");
uView.display();
uView.setFontType(2);
uView.print(Temperature); // display HelloWorld
uView.display();
Receiver Code
//Receiver Code
int val;
while (!Serial.available()){}
//delay(100); //allows all serial sent to be received together
byte b1 = Serial.read();
// delay(100); //allows all serial sent to be received together
byte b2 = Serial.read();
val = b2 + b1 *256 ;
Serial.println(val);
Tempted on sensor output, 20.62!!!! Ignoring the multiplication, any thoughts how I can turn this into a number I can give a variable name in the code so the slave can save it to an SD card.
Is using the serial going to inhibit any other serial functions.
