Serial.read and array problems
Im doing a program that it has verify that the data of serial port put in from monitor serial are equal that an array of chars definite in program.
Program:
char inChar;
char inputString[256];
char prueba = “abc”;
int i = 0;
while (Serial.available()) {
inChar = (char)Serial.read();
inputString = inChar;
  • i++;*
  • if (inChar == ‘\r’) {*
    _ inputString =’\0’;_
    * i=0;*
    * Serial.println(inputString);*
    * Serial.println(prueba);*
    * Serial.println(strcmp(inputString, prueba));*
}[/quote]
Result:
> dfg
> abc
> 3
> abc
> abc
> -87
> ghdags
> abc
> -87
> dfgsgsd
> abc
> -87
> s<s
> abc
> -87
> f<
> abc
> -87
> f<s<fsfsdsgds
> abc
> -87
If the first serial data is ‘abc’:
> abc
> abc
> 13
> fdsfsd
> abc
> -87
> dhsdgds
> abc
> -87
> dfgdgds
> abc
> -87
What is the problem?
Help me please,
Regards
Sorry, this is the program:
char inChar;
char prueba[] = "abc";
int i = 0;
    inputString[i] = inChar;
    i++;
    if (inChar == '\r') {
      inputString[i-1] ='\0';
      i=0;
What have you got the line ending set to in the Serial monitor ? If it is set to 'Both NL and CR' then the NL will mess things up because you are only testing for CR in your code.
THANKSSSSS UKHeliBob!!
+10!
