serial.read() and device it to multi string
I have a serial that return to me this answer:
result: 1, 23, 6, 0, 444, 5 (the numbers can change between 0-512)
my question is :
I know that the pattern is number and there is 6 of them.
how can I show only the results like this:
answer1=1
asnwer2=23
answer3=6
asnwer4=0
answer5=444
asnwer6=5
I have try to do this but I'm stuck
if (in_sbdi==' ')
         soa=true;
         eoa=false;
          else if (in_sbdi==',')
            soa=false;
            eoa==true;
I'm know how to recognize start\end of answer - but how do I continue from here?
Thanks ,
The strtok() function bears investigation.
I'm sorry - I don't understand your answer....
Nor did you take time to google strtok(), did you?
If the data being sent is properly comma delimited, code like below might be a start.
//zoomkat 3-5-12 simple delimited ',' string parce
//from serial port input (via serial monitor)
//and print result out serial port
// CR/LF could also be a delimiter
String readString;
  Serial.println("serial delimit test 1.0"); // so I can keep track of what is loaded
  //expect a string like wer,qwe rty,123 456,hyre kjhg,
  //or like hello world,who are you?,bye!,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      if (readString.length() >1) {
        Serial.print("answer = ");
        Serial.println(readString); //prints string to serial port out
        //do stuff with the captured readString
        readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
I have search - but it must be the time of the day - and I miss spelling it - my mistake ..........sorry
but now I know I have problems with my definition of the function
this is an example that I have found :
/* strtok example */
#include <stdio.h>
#include <string.h>
int main ()
  char str[] ="- This, a sample string.";
  char * pch;
  printf ("Splitting string \"%s\" into tokens:\n",str);
  pch = strtok (str," ,.-");
  while (pch != NULL)
    printf ("%s\n",pch);
    pch = strtok (NULL, " ,.-");
  return 0;
and this is what I have try to do :
 Serial.print(full);//this is my full answer from the device
char * pch;
pch = strtok(full,' ', ',');
while (pch!='\n')
  Serial.println ("/%s\n",pch);
here I got lost - and I don't know if until here it's O.K
Which uses two arguments - the string to tokenize and an array of delimiters.
Which tries to call strtok with three arguments. That won't work.
You only have one delimiter - the comma. So, the code looks like:
  char * pch;
  pch = strtok (str, ",");
  while (pch != NULL)
    pch = strtok (NULL, ",");
Easiest way I think:
http://codepad.org/VLfagSkg
It's said that -
call of overloades 'println(const char [34],char [44])' is ambiguous
  • what does it mean?
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
int test=7;
  pinMode(test,INPUT);
  pinMode(13,OUTPUT);
  Serial.begin(19200); // Open serial communications and wait for port to open:
  delay(1500);
  Serial.println("Ready to work!");
  mySerial.begin(19200);
  delay(1500);
  Serial.println("Modem connection is on!");
  if (digitalRead(test)==HIGH)
    char in_csq;
    char full[44];
    mySerial.println("AT+sbdi");
    delay(16000);
    if  (mySerial.available()> 7)
    {//start of  answer
      for (int csq_num=0;csq_num<43;csq_num++)
      {//start reading
        full[csq_num]=mySerial.read();
      }//end of reading
      char * pch;
      Serial.println("spliting string \"%\" into token: \n" ,full);
      pch = strtok(full,",");
      while (pch !=NULL)
        Serial.println("%s\n",pch);
        pch=strtok(NULL,",");
    }//end of reading
Also I have try the second code that was offer by
guix
and I think the problem is that this is not the full answer - this is my full answer:
AT+sbdi
+SBDI: 2,41,2,1,3,8
OK
but when I write it like it is I still don't get nothing....
this is how I wrote it:
int16_t a1,a2,a3,a4,a5,a6;
      //      sscanf(full,"at+sbdi  +sbdi: %hu,%hu,%hu,%hu,%hu,%hu"  OK,&a1, &a2, &a3, &a4, &a5, &a6);
      //      printf("answer1= %hu\n 2 = %hu\n  3 = %hu\n 4= %hu\n 5=%hu\n 6=%hu\n " , a1,a2,a3,a4,a5,a6);
Try with:
if ( sscanf( str, "at+sbdi\r\n+sbdi:%hu,%hu,%hu,%hu,%hu,%hu", &a1, &a2, &a3, &a4, &a5, &a6 ) == 6 )
  char str2[90];
  sprintf( str2,
    "answer1 = %hu\n"
    "answer2 = %hu\n"
    "answer3 = %hu\n"
    "answer4 = %hu\n"
    "answer5 = %hu\n"
    "answer6 = %hu\n",
    a1, a2, a3, a4, a5, a6
  Serial.println( str2 );
  Serial.println( "fail" );
no,sorry - still no good
I get fail
wait wait wait wait.......
I have return to the first code and I understand my mistake :blush:
now it's almost working
It's printing 5 out of the 6 numbers - just the first one I can't get. this is the code
I have enter the numbers into a variable because I need to do things with them latter.
#include <stdio.h>
int test=7;
  pinMode(13,OUTPUT);
  delay(1500);
  delay(1500);
    char  full [42];
    Serial.println("sending AT+SBDI");
    delay(16000);
    if  (mySerial.available()> 41)
    {//start of  answer
      for (int csq_num=0;csq_num<41;csq_num++)
      {//start reading
      }//end of reading
      Serial.println(full);
      delay (1000);
      Serial.println("test2..........");
      char * pch;
      int i=0;
      char *david[6];
      printf("spliting string \"%\" into token: \n" ,full);
      pch = strtok( full, ",");
      while (pch !=NULL)
        printf("%s\n",pch);
        david[i]=pch;
        i++;
for (int t=0;t<5;t++)
  Serial.print(t);
  Serial.print ("-   ");
  Serial.println(david[t]);
    }//end of reading
the IMG is what I get
What is this supposed to print? What, exactly, is the %nothing format specifier supposed to do for you?
        printf("%s\n",pch);
Is is too much to expect you to print something before and after the string to identify and bound it?
I don't see either of these statements having any impact on what is in your screenshot.
I'm learning the language from post to post.... (the new commands at least )
I didn't know what I need to put after the %
can you explain me what I need to put there ? the full string? the part I need? what?
Thanks ,(for the patience)
The % introduces a format specifier. Presumably you put it there because you want the variable formatted somehow. I suspect that %s is the correct format specifier, but that is only a(n educated) guess.
I'm sorry - but maybe my English is not as good as I think ,so let me see if I understand:
the %s stand for what? - the string "full"? right?
that mean that printf is saying :
printf("this is what you have in the string full "%s" ,full)
if this is true - I still don't see any print in the serial.- but this is not a problem.
I want to see all 6 numbers and I can only see the last 5.
this is the setup part:
int test=7;
int readbutton=6;
int sendbutton=5;
boolean cansend=false;
  pinMode(readbutton,INPUT);
  pinMode(sendbutton,INPUT);
  pinMode(13,OUTPUT);
  delay(1500);
  delay(1500);
this is the code:
void sendsbdi()
{//start of sendsbdi
char  full [42];
    delay(16000);
    {//start of  answer
      {//start reading
      }//end of reading
      delay (1000);
      char * pch;
      int i=0;
      char *david[6];
      printf("spliting string \"%s\" into token: \n" ,full); //the part of cutting the answer
      while (pch !=NULL)
        printf("%s\n",pch);
        david[i]=pch;
        i++;
      }// end of cutting the answer
      {//start of printing
        Serial.print(t);
      }//end of printing
    }//end of reading
}//end of sendsbdi
so what is wrong now?
Yes, it is.
Although, I don't see how you have created a relationship between stdout (that printf writes to) and the serial port.
Use sprintf() to write to a buffer, and Serial.print() to print the buffer, or just use Serial.print().
O.K.
(thanks )
how do I created a relationship between them?
if I try only
Serial.println("spliting string "%s" into token: \n" ,full); //the part of cutting the answer
I get error this error
call of overloaded 'println(const char [34],char [44])' is ambiguous
The Serial print methods are not like the usual C printf.
You can't use format strings like that.
True, but OP could:
char buff[160];
sprintf(buff, "spliting string \"%s\" into token: \n" ,full);
Serial.print(buff);
which WOULD support formatted printing.
Or, of course, the simpler:
Serial.print("spliting string \"");
Serial.print(full);
Serial.println("\" into tokens");
