Serial read buffer
Hello,
I have written class to read data from serial but I noticed that its hanging from time to time - and its not releasing memory after read. I know using Strings is BAAD - but can some one tell me why this code is changing when lot of data come ?
#include "SerialReader.h"
void SerialReader::init(byte id)
  this->id = id;
  if (id == 0)
    Serial.begin(19200);
  else if (id == 2)
    Serial2.begin(19200);
  else if (id == 3)
    Serial3.begin(19200);
byte SerialReader::getId()
  return id;
String SerialReader::getMessage()
  String result = "";
  if (isSerialAvaliable())
    incomingSerialMessage += String(read());
    incomingSerialMessage.toLowerCase();
  if (incomingSerialMessage.indexOf("#") >= 0)
    result = incomingSerialMessage;
    incomingSerialMessage = "";
  return result;
bool SerialReader::isSerialAvaliable()
  return ((id == 0 && Serial.available() > 0) || (id == 2 && Serial2.available() > 0) || (id == 3 && Serial3.available() > 0));
char SerialReader::read()
  char result;
  if (id == 0)
   result = (char) Serial.read();
  else if (id == 2)
   result = (char) Serial2.read();
  else if (id == 3)
   result = (char) Serial3.read();
  return result;
Example usage:
    message = serial2Reader.getMessage();
    if (!message.equals(""))
      receivedBySerial = serial2Reader.getId();
      handleCommand(message);
thanks in advance
Fragemntation is possible because memory free shows me freeMemory()=5747 - when arduino hangs
Do you have an example of "lot of data" that you are receiving?
You may be interested in Serial Input Basics - simple reliable ways to receive data without using Strings.
...R
