Serial read data from labview to another arduino wirelessly
Good day! I am doing my project hope anyone can help me with this.
In our case, we have 3 MPU6050 with arduino each and will get the Total Pitch, Yaw, and Roll through LabVIEW and manipulate the data that we need and will serve as our controller. But now that we have done it, we want to transmit the Total Pitch, Yaw, and Roll wirelessly using NRF24l01 to control the servos. If you have any idea how to do it, I would gladly appreciate if you share it with me. Thank you so much!
attached here my main program from this project in labview and the transmitter and receiver file
//TRANSMITTER/CONTROLLER SIDE
#include <SPI.h>
#include <nRF24L01.h>
#include <printf.h>
#include <RF24.h>
#include <RF24_config.h>
const int CE = 9;
const int CSN = 10;
RF24 radio (CE , CSN );
const uint64_t canal[2]= {0xE8E8F0F0E1LL,0xE8E8F0F0E2LL};
int data;
radio.begin();
radio.setRetries(5,10);
radio.openWritingPipe(canal[0]);
radio.openReadingPipe(1,canal[1]);
radio.setPALevel(RF24_PA_MAX);
  // TRANSMIT
  radio.stopListening();
  while (Serial.available()){
  data= Serial.read();
  radio.write(&data,sizeof(data));
//RECEIVER/ACTUATOR SIDE
#include <SPI.h>
#include <printf.h>
#include <RF24.h>
const int CE = 9;
const int CSN = 10;
int data;
radio.begin();
radio.openWritingPipe(canal[1]);
radio.openReadingPipe(1,canal[0]);
//RECEIVE
radio.startListening();
if (radio.available())
  radio.read(&data,sizeof(data));
  Serial.println(data);
  delay(50);
This is the flow diagram that we will be doing
This is our labVIEW vi part 1
This is our labVIEW vi part 2
This tutorial explains how to use those radios with Arduinos.
Please edit your post to add code tags.
I have edited the codes, how will I get the data from labview and transmit it to another PC/laptop? Is there anyway possible?
@angge097 ,
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
Sounds like PC to PC communications. Where does Arduino figure in to this?
How does this relate to the question in your first post?
One single Arduino can read 3 MPU-6050, process the data and control 3 servos. No need for Labview.
Yup.
LabVIEW could send it by Ethernet to another PC(you could even send it by serial, but over ethernet). By Wifi. By you name it. Lots of ways, in LabVIEW, all outside the scope of the Sensor forum.
However, let's see if anyone else throws in an answer.
Me, I'd be wondering why all the hoops. You're making this complex. You could buy Arduinos with built in Wifi and send data from them to LabVIEW, then LabVIEW to your output Arduinos.
Or, are you stuck with hardware someone's already got, so that constrains your approach? There's an area on this forum for Project Advice/Design, where this might be a better topic.
I am sorry for that, its just the system hidden my post so I posted again another topic. The duplicate topic is deleted now. Thank you and I'm sorry for the inconvenience
It's just that we are required to communicate and use the LabVIEW program in this project and the controller must be wirelessly transmitted using the nrf24l01
There is certainly no reason to use Labview on the receiver side. One Arduino can receive wireless data or commands and control three servos.
Hi, my answer to all this is we have to transmit the controller data to the receiver side using the nrf24l01 because it is required tool for us to use in this project. I hope there is a way through this, thank you
Can you tell me on how will I do that? I really don't have any idea on how will I get those data
You could follow the NRF24L01 tutorial I linked, and learn to send yaw, pitch and roll angles (one line of comma separated numbers, for example) to the Arduino that controls the servos.
The Simple one way transmission example is all you need, although you would substitute formatted values for the message sent.
where can I find the link for this? Thank you so much
Linked in post #5.
Check out this video this might help you.
He has demonstrated how you can use nrf module with Arduino and explained code in detail
Hi, can I ask on how to do it? do you have any available code or tutorial? I am using the arduino library <MPU6050_light.h> to get the Pitch, Roll, and Yaw angles.
I will try to use this concept . Thank you so much in advance!
I think you only need two Arduino like this
