Serial read does not work (if(value == 1))
I have problem with serial.read().
I need that when I enter a value of "1", so that divorced IF which lists the current temperature. I do not want to keep me Arduino via delay() list each temperature, but I want to list only the temperature of 1x based on a value of "1".
IF value of work. Why?
  if(Serial.available())
    byte value = Serial.read();
     if(value == 1)
      Serial.write(value);
That collection of words does not form a useful thought.
     if(value == 1)
What is sending the data? If the data is sent as text, you should be testing for having received the character 1, not the value 1.
    if(value == '1')
Because you are NOT entering a value of 1 you typed the char '1' ! you have never entered a number on a keyboard you have entered the chars 1 2 3 etc.
Mark
I will send data from Raspberry. When you send the number "1," I need to get the current temperature of the Arduino.
Here is a python code
import serial
s = serial.Serial(port='/dev/tty.AMA0', baudrate=9600)
s.write("1")
data = s.read()
print(data);
s.close()
When you send "1", you are sending the character '1', NOT the value 1.
