i want to write code for my arduino for echo communication but have some problem
the code should look more or less like this
if i send to serial monitor "L90" he should turn my servo to left 90 degrees
can some one help?
What have you tried? Doing what you want is trivial. There are dozens of examples posted every data for reading serial data and storing it in an array. There are daily examples for parsing that data. There are daily examples of converting a string to an int.
Which of them have you failed to find? Which did you fail to find because you failed to look?
Indeed Paul. Also, without YOUR code, we can't help.
u help some how and now have some problem with verifying
error: invalid conversion from 'int*' to 'int'
and this is the error in code
int nextVal = serialValues;
We don't do keyhole surgery.
Post your code.
char inData[10];
int index;
boolean started = false;
boolean ended = false;
boolean final = false;
int serialValues[16];
int serialIndex = 0;
const int Pin13 = 13;
const int Pin12 = 12;
const int Pin11 = 11;
const int Pin10 = 10;
int buttonState1 = 0;
int buttonState2 = 0;
//Serial1.begin(9600);
//setting pinouts
pinMode(Pin13, OUTPUT);
pinMode(Pin12, OUTPUT);
pinMode(Pin11, INPUT);
pinMode(Pin10, INPUT);
buttonState1 = digitalRead(Pin11);
buttonState2 = digitalRead(Pin10);
while(Serial.available() > 0)
char aChar = Serial.read();
if(aChar == '<')
started = true;
index = 0;
inData[index] = '\0';
else if(aChar == '>')
ended = true;
else if(started)
inData[index] = aChar;
index++;
else if (aChar =='*')
final = true;
if(started && ended)
// Convert the string to an integer
int inInt = atoi(inData);
Serial.println(inInt);
// Use the value
serialValues [serialIndex] = inInt;
serialIndex++;
// Get ready for the next time
started = false;
ended = false;
index = 0;
if(final)
while(1)
// loop through the serialValues, and do something
for(int b=0; b <16;b++ )
//if serial value is 24 and pin10 is connected to 5V switch led12 on
if (nextVal == 24 && buttonState2 == HIGH)
digitalWrite(Pin12, HIGH);
//if serial value is 12 and pin11 is connected to 5V switch led13 on
if (nextVal == 12 && buttonState2 == LOW)
digitalWrite(Pin12, LOW);
Serial.println(b);
int nextVal = serialValues[b];
dude i find my self embarrassed
but no one know everything from start
and now the game begin
Entirely agree with you.
