butthis code still does not fallow through with the function
Take a look at ALL the places where readString appears. Show ALL the places where readString gets data added to it. I'll wait.
im thinking nowhere .....
so if the string is coming from the serial read and char c is serial read would i make readstring = c ?
NOW you are thinking correctly.
No, you would APPEND the character to readString:
readString += c;
alright so now i have it printing in uppercase but still no function and it serial prints both literal and upper case muiltiple times
#include <MotorDriver.h>
String readString;
Serial.begin(57600);
if (Serial.available())
char c = Serial.read(); //gets one byte from serial buffer
Serial.print(c);
readString += c; //makes the string readString
if (readString.length() > 0)
readString.toUpperCase();
Serial.println(readString);
if (readString == "SQUARE JUST PRESSED")
motordriver.goForward();
You still print each letter:
Serial.print(c);
And the whole recieved buffer:
So thats to be expected.
Currently you have no way to clear that buffer, You'll need some sort of delimiter to trigger the clear, the character /r should work.
so
if( c == '/r' )
readString = "";
tammytam:
Currently you have no way to clear that buffer, You'll need some sort of delimiter to trigger the clear, the character /r should work.so
if( c == '/r' )
readString = "";
'/r' is two characters. '\r' is one character. / is slash. \ is backslash and is an escape character in C.
still is doing the same after adding that
String readString;
if ( c == '/r' )
readString = "";
Read what christop said. I used the incorrect slash, time to call it a day for me I think ;).
Ok I'll try it thanks everyone
ok changed the slash and it works but im still not getting it to "goForward" when the SQUARE JUST PRESSED is recieved......
Because that is what you told it to do. If you, as I suspect, only want to check readString after the \n or \r arrives, then you need to make some changes.
should be
if(c == '\n' || c == '\r')
You'll also need to reset readString to an empty string somewhere.
i made the changes still no forward movement
String readString;
if ( c == '\r' )
readString = "";
code correction
String readString;
if (c == '\n' || c == '\r')
if ( c == '\r' )
readString = ""; //clears variable for new input
Perhaps you should reexplain in detail just what you want/expect your code to do.
For now when it receives "square just pressed" I want it to fallow through with the motordtiver function goforward
merkzilla:
Maybe something simple to start with.
// zoomkat 8-6-10 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
//A very simple example of sending a string of characters
//from the serial monitor, capturing the individual
//characters into a String, then evaluating the contents
//of the String to possibly perform an action (on/off board LED).
int ledPin = 13;
String readString;
pinMode(ledPin, OUTPUT);
Serial.println("serial on/off test 0021"); // so I can keep track
while (Serial.available()) {
delay(3);
readString += c;
if (readString.length() >0) {
if(readString.indexOf("on") >=0)
digitalWrite(ledPin, HIGH);
Serial.println("LED ON");
if(readString.indexOf("off") >=0)
digitalWrite(ledPin, LOW);
Serial.println("LED OFF");
readString="";
I HATE crap like this. Learn what is REALLY in readString by printing it better:
Serial.print("readString = >");
Serial.print(readString);
Serial.println("<");
If you see:
readString = >SQUARE JUST PRESSED<
you have learned one thing.
If you see:
you have learned something else.
With your method, the output would look the same, and you can NOT tell what is REALLY in readString.
SQUARE JUST PRESSED
readString = ><
SQUARE JUST RELEASED
readString = >SQUARE JUST RELEASED<
readString = ><
so guess ive learned one thing but im missing something else what does this mean?
