Serial.read() error
I have been trying on inputting a number on a serial monitor and according to the codes provided by the book,Arduino Workshop ed.2013, the output should return a value a number multiplied by two. However, in my case based on the image I have provided, every time I input a number it returns a number multiplied by two and a redundant output by which the correct output precedes:
"You entered: -38
"-38 multiplied by two is -76".
And Here's the code by the way:
int number;
     number = 0; // zero the incoming number ready for a new read
     Serial.flush(); // clear any "junk" out of the serial buffer before waiting
             while (Serial.available() == 0)
               // do nothing until something enters the serial buffer
             while (Serial.available() > 0)
               number = Serial.read() - '0';
               // read the number in the serial buffer,
               // remove the ASCII text offset for zero: '0'
                 // Show me the number!
                 Serial.print("You entered: ");
                 Serial.println(number);
                 Serial.print(number);
                 Serial.print(" multiplied by two is ");
                 number = number * 2;
I've been trying find ways to debug the code but nowhere to find. Hope to find an early solution
By the way, the error is on the picture I provide
Change the serial monitor line-ending to "none"
Serial.flush(); // clear any "junk" out of the serial buffer before waiting Wrong.
Please remember to use code tags when posting code.
It did work. Thanks
TheMemberFormerlyKnownAsAWOL:
There are only the following 4 options (literally) in the Line ending tab of the Serial Monitor (Fig-1):
No line ending
Newline
Carriage return
Both NL & CR
Should "none" be replaced by "No line ending"?
Figure-1:
