Serial read from ETS2
Hello it's evryone
im have trouble with LIGHT_PARK beacouse ist light always on when the other diodes connected to the analog ports work fine and I would like to ask for help in finding the reason because I only have 6 analog ports.
Thank you in advance for your help
Copyright (c) 2013, Silas Parker
All rights reserved.
Redistribution and use in source and binary forms, with or without modification,
are permitted provided that the following conditions are met:
    Redistributions of source code must retain the above copyright notice, this
    list of conditions and the following disclaimer.
    Redistributions in binary form must reproduce the above copyright notice,
    this list of conditions and the following disclaimer in the documentation
    and/or other materials provided with the distribution.
    The name of Silas Parker may not be used to endorse or promote products
    derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <LiquidCrystal.h>
#include <Servo.h>
const int SPEEDO_PIN      = A1;
const int RPM_PIN         = A0;
const int LEFT_INDICATOR  = A2;
const int RIGHT_INDICATOR = A3;
const int PARKING_BREAK   = A4;
const int FUEL_WARNING    = A5;
const int LIGHT_PARK      = 3;
const int LIGHT_LOW       = 4;
const int LIGHT_HIGH      = 5;
// Servo variables
Servo speedo;
Servo rpm;
#define PACKET_SYNC 0xFF
#define PACKET_VER  2
#define SERVO_DIR_NORMAL false
#define SERVO_DIR_INVERT true
int serial_byte;
LiquidCrystal lcd(12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2);
  lcd.begin(16, 2);
  lcd.print("Self Test");
  // Initialise servos
  speedo.attach(SPEEDO_PIN);
  speedo.write(180);
  rpm.attach(RPM_PIN);
  rpm.write(180);
  // Initialise LEDs
  pinMode(LEFT_INDICATOR, OUTPUT);
  pinMode(RIGHT_INDICATOR, OUTPUT);
  pinMode(PARKING_BREAK, OUTPUT);
  pinMode(FUEL_WARNING, OUTPUT);
  pinMode(LIGHT_PARK, OUTPUT);
  pinMode(LIGHT_LOW, OUTPUT);
  pinMode(LIGHT_HIGH, OUTPUT);
  digitalWrite(LEFT_INDICATOR, 0);
  digitalWrite(RIGHT_INDICATOR, 0);
  digitalWrite(PARKING_BREAK, 0);
  digitalWrite(FUEL_WARNING, 0);
  digitalWrite(LIGHT_PARK, 0);
  digitalWrite(LIGHT_LOW, 0);
  digitalWrite(LIGHT_HIGH, 0);
  speedo.write(0);
  rpm.write(0);
  digitalWrite(LEFT_INDICATOR, 1);
  digitalWrite(RIGHT_INDICATOR, 1);
  digitalWrite(PARKING_BREAK, 1);
  digitalWrite(FUEL_WARNING, 1);
  digitalWrite(LIGHT_PARK, 1);
  digitalWrite(LIGHT_LOW, 1);
  digitalWrite(LIGHT_HIGH, 1);
  speedo.write(180);
  rpm.write(180);
  lcd.clear();
  lcd.print("Wait");
  // Wait a second to ensure serial data isn't from re-programming
  lcd.clear();
  lcd.print("Ready");
void read_serial_byte_set_servo(Servo& servo, bool invert)
  serial_byte = Serial.read();
  serial_byte = (serial_byte < 0) ? 0 : ((serial_byte > 180) ? 180 : serial_byte);
  if (invert)
    servo.write(180 - serial_byte);
    servo.write(serial_byte);
void skip_serial_byte()
  (void)Serial.read();
void digitalWriteFromBit(int port, int value, int shift)
  digitalWrite(port, (value >> shift) & 0x01);
  if (Serial.available() < 16)
    return;
  if (serial_byte != PACKET_SYNC)
    return;
  if (serial_byte != PACKET_VER)
    lcd.clear();
    lcd.print("PROTOCOL VERSION ERROR");
    return;
  read_serial_byte_set_servo(speedo, SERVO_DIR_INVERT); // Speed
  read_serial_byte_set_servo(rpm, SERVO_DIR_INVERT); // RPM
  skip_serial_byte(); // Brake air pressure
  skip_serial_byte(); // Brake temperature
  skip_serial_byte(); // Fuel ratio
  skip_serial_byte(); // Oil pressure
  skip_serial_byte(); // Oil temperature
  skip_serial_byte(); // Water temperature
  skip_serial_byte(); // Battery voltage
  // Truck lights byte
  digitalWriteFromBit(LEFT_INDICATOR,  serial_byte, 5);
  digitalWriteFromBit(RIGHT_INDICATOR, serial_byte, 4);
  digitalWriteFromBit(LIGHT_PARK, serial_byte, 6);
  // Warning lights bytes
  digitalWriteFromBit(PARKING_BREAK, serial_byte, 7);
  digitalWriteFromBit(FUEL_WARNING, serial_byte, 3);
  // Enabled flags
  // Text length
  int text_len = Serial.read();
  // Followed by text
  if (0 < text_len && text_len < 127)
    lcd.clear();
    for (int i = 0; i < text_len; ++i)
      while (Serial.available() == 0) // Wait for data if slow
        delay(2);
      if (serial_byte < 0 && serial_byte > 127)
        return;
      if (serial_byte == '\n')
        lcd.setCursor(0, 1);
        lcd.print(char(serial_byte));
//      delay(2);
Please, post your project wiring.
Sorry for the wrong section. This is photo of mounting system.
I'm a little confused as I do not see an LCD but you do include a file for it. Next you use LiquidCrystal lcd(12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2) which seems to share some pins with the three LED pins?
It looks like you're using the 8-bit interface for the lcd; any reason for that?
Thanks for your help I completely forgot about it. I will change it to one with i2c.
Arduino is not a power supply.
Servos consume more current than the Arduino can supply.
Powering your servo through the Arduino can damage it.
Power the servo directly from a source.
I suspect that it's currently powered from the USB as there is nothing connected to the barrel.
Yea im know im power servos and lcd scren by 9v battery through a 5v voltage stabilizer
I don't understand, it's separate and only the data pin is connected to the Arduino. How to get 5v with AA batteries, also through a stabilizer?
Hi, @hukujestemsmok
Do you have a DMM? Digital MultiMeter?
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
Yes im have.
Use the DMM to monitor the 9V supply.
Tom.. :grinning: :+1: :coffee: :australia:
Last time i buy something like this to monitor source voltage but it still on the way
While doing your tests, measure the battery voltage with the DMM, to see if the the voltage changes.
This is a basic troubleshooting proceedure.
