Serial.read is -1?
Testing my program by connecting two Arduino`s together via serial, Tx - Rx
Program starts with no connection and waits for data, serial is connected, data is read, but a string of -1 is added to it.
If disconnect the serial connection, serial is still read, but with all -ones.
I would have thought that with no data input, the program would wait?
Here`s part of receive test code
  if (Serial.available() > 0 ) {
   while (inByte != 0xFF)
         inByte = Serial.read();
         counter++;
        Serial.print(inByte);
        Serial.print("");
   Serial.println("");
   Serial.println("");
  Serial.print("Counter is ");
 Serial.println(counter);
   Serial.println("Run-in Ended");
   Serial.println("");
    counter = 0;
  } //SerialEnd
} //LoopEnd
Output on Serial Monitor
10-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1858585858585858585858585858585858585858585858585858585858585255
Counter is 60
Run-in Ended
Thanks.
Your second read doesn't check to see if there's any data there.
Returns
the first byte of incoming serial data available (or -1 if no data is available) - int
We can't see the declaraction of "inByte" (Big Hinttm), but if it is an "int", it unlikely to ever be equal to 0xFF
Ah... :slight_smile: Where did I get the idea that an int was 0-255?? :smiley:
Changed int to byte... upwards and onwards! :slight_smile:
