I am attempting to make a motor controller that also shows what speed the motor is set to on an lcd, the project is currently on two arduinos, one to run the motor and one for the lcd b/c when they were run on the same arduino the lcd slowed the motor down. I am having issues receiving data on the lcd arduino. The first 10-20 loops are accurate and shows the correct number, but after that the data breaks down and shows the correct numbers in incorrect patterns, i.e. instead of '1023' it returns:
1
1221
30121
321
the tx and rx pins are correctly connected and so are the grounds
I have attached my code below, what am I doing wrong?
Code for motor
#include <AccelStepper.h>
// Define stepper motor connections
#define dirpin 2 // Direction Pin
#define steppin 4 // Stepper Pin
#define motorInterfaceType 1
int potentiometer = A0; // Potentiometer Pin
int i = 0; // Setup Loop variable
int howfast = 0; // Mapped Speed
AccelStepper stepper = AccelStepper(motorInterfaceType, steppin, dirpin);
Serial.begin(9600); // Serial read begin,
pinMode(potentiometer, INPUT);
pinMode(steppin, OUTPUT);
pinMode(dirpin, OUTPUT);
digitalRead(dirpin); //direction pin either LOW or HIGH to move in either direction
// Set the maximum speed in steps per second:
stepper.setMaxSpeed(3000);
senddata();
for (int i = 0; i < 10; i++)
// Set the speed in steps per second:
stepper.setSpeed(howfast);
// Step the motor with a constant speed as set by setSpeed():
stepper.runSpeed();
void senddata() {
howfast = analogRead(potentiometer);
Serial.println(howfast);
delay(1);
Code for lcd (from Serial Input Basics thread)
#include <Wire.h>
#include <LiquidCrystal_I2C.h> // LCD Library
const byte numChars = 32;
char receivedChars[numChars]; // an array to store the received data
boolean newData = false;
int dataNumber = 0; // new for this version
LiquidCrystal_I2C lcd(0x27, 16, 2); // set the LCD address to 0x27 for a 16 chars and 2 line display
Serial.println("<Arduino is ready>");
lcd.init(); // initialize the lcd
lcd.init();
recvWithEndMarker();
Serial.println(receivedChars);
// LCD Screen;
lcd.backlight();
// print out string
lcd.setCursor(2, 0);
lcd.print("Motor Speed");
// print out the value on LCD:
lcd.setCursor(6, 1);
lcd.print(receivedChars);
void recvWithEndMarker() {
static byte ndx = 0;
char endMarker = '\n';
char rc;
if (Serial.available() > 5) {
rc = Serial.read();
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
