serial - read line
Hello,
i want to receive a line of text, with variable length into a string on the arduino.
Is there a easy way to read a whole line into a string or do i have to make a loop and read it byte per byte till LF is detected?
No, there is no single way.
It depends how you send the string too.
If you send something from the serial monitor, there is no automatic delimiter, like CR sent.
What does a typical line looks like?
i send it from a python script, so i can include a LF at the end, that should not be a problem.
a typical line looks like this:
M104 P200
where the M104 stands for the command and 200 is the value to the command.
blocking version of getline()
void getline(char * buffer)
  uint8_t idx = 0;
  char c;
  do
    while (Serial.available() == 0) ; // wait for a char this causes the blocking
    c = Serial.Read();
    buffer[idx++] = c;
  while (c != '\n' && c != '\r');
  buffer[idx] = 0;
to be expanded with max chars param
drawback of this version is that it blocks, a nonblocking version is more difficult as a function as it needs to hold state.
thanks for the source.
the blocking should not be a problem.
i'll put a query for serial available in the loop then the function will only be executed if there is somthing to read.
If your strings are allways size 8 you can do:
if (Serial.available() >=8)
b = getLine(buffer);
