Serial.read multiple parameters
Hello,
I have some serial data from a PSOC micro-controller in this format :
printf("z %i \n x %i \n e%i \n y %i \n",z_value,moving_mean_z,error,out).
I can change the format if that's easier
Now I want to read them from an ESP32 (Arduino IDE) so I can write them to a web app.
I want the parameters separated (variable for z, variable for x, variable for e and variable for y).
I tried to do that with this code but I get some errors :
error:'z' was not declared in this scope
error: 'x' was not declared in this scope
error: 'e' was not declared in this scope
error: 'y' was not declared in this scope
error: expected '}' at end of input
I know that they are not declared but they are chars from the Serial.read.
How can I fix this? Or is there an easier way to separate the parameters?
const unsigned int MAX_MESSAGE_LENGTH = 12;
void loop(){
  //const char parameter = Serial.read;
  switch (Serial.read())
    case z:
    // doe iets
    while (Serial.available() > 0) { //check serial buffer
    static char z_value[MAX_MESSAGE_LENGTH]; // create place to store incomming message
    static unsigned int z_value_pos = 0;
    char inByte = Serial.read();
    if(inByte != '\n' && (z_value_pos < MAX_MESSAGE_LENGTH -1)){
      z_value[z_value_pos] = inByte;
      z_value_pos++;
    else{
      z_value[z_value_pos] = '\0';
      Serial.println(z_value);
      z_value_pos = 0;
    case x:
    // doe iets
    static char moving_mean[MAX_MESSAGE_LENGTH]; // create place to store incomming message
    static unsigned int moving_mean_pos = 0;
    if(inByte != '\n' && (moving_mean_pos < MAX_MESSAGE_LENGTH -1)){
      moving_mean[moving_mean_pos] = inByte;
      moving_mean_pos++;
    else{
      moving_mean[moving_mean_pos] = '\0';
      Serial.println(moving_mean);
    case e:
    //doe iets
    static char error[MAX_MESSAGE_LENGTH]; // create place to store incomming message
    static unsigned int error_pos = 0;
    if(inByte != '\n' && (error_pos < MAX_MESSAGE_LENGTH -1)){
      error[error_pos] = inByte;
      error_pos++;
    else{
      error[error_pos] = '\0';
      Serial.println(error);
      error_pos = 0;
    case y:
    // doe iets
    static char out[MAX_MESSAGE_LENGTH]; // create place to store incomming message
    static unsigned int out_pos = 0;
    if(inByte != '\n' && (out_pos < MAX_MESSAGE_LENGTH -1)){
      out[out_pos] = inByte;
      out_pos++;
    else{
      out[out_pos] = '\0';
      Serial.println(out);
      out_pos = 0;
sketch_nov28a.ino (2.1 KB)
Try:
case 'z':
Then I get this:
C:\Users\siebe\Documents\Arduino\sketch_nov28a\sketch_nov28a.ino: In function 'void loop()':
C:\Users\siebe\Documents\Arduino\sketch_nov28a\sketch_nov28a.ino:30:10: error: jump to case label [-fpermissive]
case 'x':
C:\Users\siebe\Documents\Arduino\sketch_nov28a\sketch_nov28a.ino:18:10: note: crosses initialization of 'char inByte'
C:\Users\siebe\Documents\Arduino\sketch_nov28a\sketch_nov28a.ino:47:10: error: jump to case label [-fpermissive]
case 'e':
C:\Users\siebe\Documents\Arduino\sketch_nov28a\sketch_nov28a.ino:35:10: note: crosses initialization of 'char inByte'
C:\Users\siebe\Documents\Arduino\sketch_nov28a\sketch_nov28a.ino:64:10: error: jump to case label [-fpermissive]
case 'y':
C:\Users\siebe\Documents\Arduino\sketch_nov28a\sketch_nov28a.ino:52:10: note: crosses initialization of 'char inByte'
C:\Users\siebe\Documents\Arduino\sketch_nov28a\sketch_nov28a.ino:84:1: error: expected '}' at end of input
C:\Users\siebe\Documents\Arduino\sketch_nov28a\sketch_nov28a.ino:32:36: note: to match this '{'
C:\Users\siebe\Documents\Arduino\sketch_nov28a\sketch_nov28a.ino:15:36: note: to match this '{'
C:\Users\siebe\Documents\Arduino\sketch_nov28a\sketch_nov28a.ino:12:3: note: to match this '{'
C:\Users\siebe\Documents\Arduino\sketch_nov28a\sketch_nov28a.ino:8:12: note: to match this '{'
void loop(){
exit status 1
Compilation error: jump to case label [-fpermissive]
And it might be better to see first if there is actually a character waiting for you to read.
Your code works OK if it works because you have a switch/case with no case matching -1, the value you are probably getting most of the time: no character available, boss.
You can use Serial.available() to see if reading makes any sense.
a7
You could either move those declarations out of the case they appear in, or enclode all the code in each case in { braces }.
I put declarations outside the switch/case statement.
HTH
a7
What do you mean with the case matching-1?
All of your while statements are missing a }.
If you add one before each break, your sketch will compile.
Among other things already mentioned you have missing closing braces '}'
Like if you had another case
    case -1 :
      Serial.println)"no character availbe!");
You'd see a crap ton of printing saying so. As you have it now, the fact is silently just being "handled" by being ignored.
Which as I said, is OK but maybe you'd like to know that is what is happening.
a7
Look at just the 'z' case. First you haven't checked to see if there is a byte available before executing the switch statement. But even if you did, your while loop will likely process just one character before exiting (because another won't be available on the next iteration), leaving any other characters unread. This means the next execution of loop() will result in reading the next character with the switch statement and it will not match any of the cases.
You need to restructure your logic.
    case 'z':
      // doe iets
        if (inByte != '\n' && (z_value_pos < MAX_MESSAGE_LENGTH - 1)) {
          z_value_pos++;
        else {
          z_value_pos = 0;
So what you mean is that he will leave the while loop as soon as the inByte changes.
How do you think I can store all the characters of 1 parameter? I have to keep reading till the \n comes. for just 1 parameter it's easy but this was the only thing I could mention for multiple parameters.
I think it would be better to read the serial until a '\n' is encountered. Then test the first character to see which data value it is. The code would be shorter and easier to 'sanity check'.
I'll try that
Sort of like:
char msg[MAX_MESSAGE_LENGTH];
int pos = 0;
  if (Serial.available())
    if (inByte == '\n')
      msg[pos] = '\0';
      pos = 0;
      // TBD: process value
    else if (pos < MAX_MESSAGE_LENGTH)
      msg[pos++] = inByte;
Tis makes a lot of sense. I think this would help me out
