Serial.read Odd behavior
Hello I have this simple pice of code and when I press 0 for instance I got an 48 for ASCCI 0 what is OK, but then w chances to 10 and I don't have a clue why that is ?!
uint8_t w
if (Serial.available() > 0) { w = Serial.read(); // Serial.print("Got a byte : "); // Serial.println(w, DEC); }
switch (w) { case 48: Cycle(); break; case 49: FadeOut(); break; case 50: Mode1(); break; } */
delay(10);
Serial.print("Loop : "); Serial.println(w, DEC);
Did you press return after you pressed 0?
ASCII 10 is the code for a line feed.
Check the Line ending setting in the Serial monitor
10 is the ASCII code for Linefeed, which is what I suspect you have the Line ending set to
