Serial.read only receives one digit at a time.
So in my code I need to send a number between 1 and 100. However, when i send a number over 9 it separates it into two different digits when it receives it. I cant understand how to fix this. Thanks in advance. Also, in the code I know i have set the max to 10 but that is for testing purposes only.
chapter_4_assignment.ino (1.36 KB)
Convert it to HEX before sending it (0x00 to 0xff, which is 0 to 255 decimal), than unconvert it when you receive it.
Thanks for the help but honestly, I just started to learn coding so i don't know how to do that.
We are glad to help but we will not complete your homework for you.
Use Serial.parseInt(). This tutorial may help: ReadASCIIString
Great i saw this post in paid section. So I decided to make code and now i see, moderator closed that lol. So here you have code for which i spent my time. Happy school homework!
And also. Don't post half of codes. You haven't posted (in paid section) setup function, global variables, etc.
/*|SKETCH FOR SIMPLE GUESSER                                 |*/
/*|Author: Bc. MARTIN CHLEBOVEC (martinius96)                |*/
/*|EMAIL: martinius96@gmail.com                              |*/
/*|WEB: https://arduino.php5.sk?lang=en                      |*/
const int greenLed = 4;
const int redLed_1 = 5;
const int redLed_2 = 6;
const int yellowLed = 7;
int secretNumber;
  Serial.println("New Game!");
  delay(700);
  Serial.println("Goal: Guess the secret number.");
  delay(700);
  Serial.println("What is your guess?");
  // initialize each of the digital pins as an output
  pinMode(greenLed, OUTPUT);
  pinMode(redLed_1, OUTPUT);
  pinMode(redLed_2, OUTPUT);
  pinMode(yellowLed, OUTPUT);
  randomSeed(analogRead(A0)); // This seeds the secret number.
  secretNumber = random(101); // Secret number from range: 0-100
  Serial.println("SECRET NUMBER IS: ");
  Serial.println(secretNumber);
  while (Serial.available() <= 0) {
    Serial.println(" GUESS THE NUMBER! ");
  digitalWrite(redLed_1, LOW);
  digitalWrite(greenLed, LOW);
  digitalWrite(redLed_2, LOW);
  digitalWrite(yellowLed, LOW);
  if (Serial.available() > 0) {
    // read the input from keyboard (the guess)
    long theGuess = Serial.parseInt(); //long because of parseInt is long!!!
    // The Guess is printed to the serial monitor
    Serial.print("You Guessed ");
    Serial.println(theGuess);
    if (theGuess == secretNumber) {
      digitalWrite(greenLed, HIGH);
      Serial.println("You won !");
      while (1);
    if (theGuess > secretNumber) {
      digitalWrite(redLed_1, HIGH);
     Serial.println("Your number is higher than secret number !");
    if (theGuess < secretNumber) {
      digitalWrite(redLed_2, HIGH);
      Serial.println("Your number is lower than secret number !");
    if (theGuess >= (secretNumber - 2)) {
      digitalWrite(yellowLed, HIGH);
      Serial.println("Your are so close! Keep trying");
Gurveer777:
That's what Serial.print() is intended to do. For example "73" is the two characters '7' and '3'. If you want to send a byte value (i.e. a value between 0 and 255) use Serial.write().
However it makes debugging much easier if you send data as human readable text. I would only send binary data if it was the only way to achieve the required performance.
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
The technique in the 3rd example will be the most reliable. It is what I use for Arduino to Arduino and Arduino to PC communication.
You can send data in a compatible format with code like this (or the equivalent in any other programming language)
Serial.print('<'); // start marker
Serial.print(value1);
Serial.print(','); // comma separator
Serial.print(value2);
Serial.println('>'); // end marker
...R
martinius96:
There's a paid section?
12Stepper:
I think i wrote it wrong. There is section named Gigs & Collaborations. Where people write gigs about what they want to be created, etc... And then people offer them solution for money :slight_smile:
I thought for a moment you meant there was a part where we had to pay to join.
(Because I paid to join here where I bought a genuine Arduino branded Uno :wink: )
