Hello,
I am trying to read values coming in from the serial port of a ESP8266. The values can be 2, 3, or 4 digit values.
Everything works as long as the data is more than 2 digits. But if the data is 2 digits, then most of
the time a random value is added to its LSB.
For example if the data is 35. Then it shows me a value of 351, or 350, or 358.
I used to terminate the data with "\n" sending out of the ESP8266 to the MEGA2560. I then
changed it to a value of "Z". But it did not make any difference.
Any ideas. Here is my code
void Rcv_Temp() // This routine updates the Cooling Menu Temperature every time Cooling Web Page is called
char buff[6]; // This is used for reading data coming in - 6 bytes
char buffer[4]; // Serial read only reads one byte at a time. So we need
int index, n, m, i; // to create a buffer to store each there. Once we receive
// a 'Z' from the serial port, then we
// put bytes together to get the integer value received
// First data coming in is FWD Temperture, the second is AFT temp
// I tried ending the DATA with carriage return('\n'). But if the Data
// coming in is less than 3 digits, it gets corrupted and add a digit
// to the LSB.
for (i=0; i<50; i++) // Loop 50 times to make sure that you receive the Temp coming in
server.handleClient();
if (Serial.available())
// Store the incoming data one byte at a time in the buffer
index = Serial.readBytesUntil('Z', buffer, 4); // new line every 4 chars.
if (buffer[0] == 'F')
int n = atoi(buffer + 1); // exclude the first char 'F' and convert the rest to integer
Serial.println(n); // For trouble shooting only. We dont want to send it to MEGA2560
buffer[0] = '\0'; // end Terminate the buffer
Temperature = String(n); // pass the value to the Temperature to send out to the website
if (buffer[0] == 'A')
int m = atoi(buffer + 1); // exclude the first char 'A' and convert the rest to integer
Temperature1 = String(m); // pass the value to the Temperature to send out to the website
Thanks
