Serial.read() Serial.write() LEDs not turning on [FIXED]
[SOLVED - THANKS TO THE EYES OF GRUMPY_MIKE]
I have a strange suspicion as always, that this may be a simple error hidden from my little designer trying to program mind but I’ve literally gone in and out of anything I could find to solve it.
This is my first post so let me know if there’s anything additional I need to post up.
I would like my LED to fade in and then out as it does currently. But for some reason when my twitter responds and i try to trigger serial.write(‘H’) to my Arduino from Processing, my lights aren’t responding.
Could someone please help? I’d be eternally greatful.
const int numReadings = 1;
int readings[numReadings];      // the readings from the analog input
int index = 0;                  // the index of the current reading
int total = 0;                  // the running total
int average = 0;
int SENSOR = 1;
int ledPin = 3;
char val;
int fade = 0;
  pinMode(SENSOR,INPUT);
  pinMode(ledPin,OUTPUT);
   if (Serial.available() > 0) {
    while (Serial.available() > 0) val = Serial.read(); //arduino-processing evening read speed
  for (int thisReading = 0; thisReading < numReadings; thisReading++)
  readings[thisReading] = 0;
  bool bBelow = false;
  total= total - readings[index];           // subtract the last reading:
  readings[index] = analogRead(SENSOR);
  total= total + readings[index];          // add the reading to the total:
  index = index + 1;                       // advance to the next position in the array:
  if (index >= numReadings) {             //back to beginning
    index = 0;
  average = total / numReadings;             // calculate the average:
 while (val == 'H') {
   digitalWrite(ledPin, 100);
  if ( average < 30)
    bBelow = true;
    Serial.write(bBelow);
  else {
    bBelow = false;
  if (bBelow)
    fade = constrain(fade,0,255);
    analogWrite(ledPin, fade);
    fade += 1;
    fade -= 1;
import processing.serial.*;
import twitter4j.conf.*;
import twitter4j.internal.async.*;
import twitter4j.internal.org.json.*;
import twitter4j.internal.logging.*;
import twitter4j.http.*;
import twitter4j.api.*;
import twitter4j.util.*;
import twitter4j.internal.http.*;
import twitter4j.*;
import ddf.minim.*;
Minim minim;
AudioSample bird;
AudioSample crowd;
static String OAuthConsumerKey = "1HSzRRYB9ut4dJNCpslrCw";
static String OAuthConsumerSecret = "8SzVraC7Ga579OLuElqMUkuYpDA2pjNUrKLSrHcv6w";
static String AccessToken = "416197785-tTqgADnyKE6NpGCU4YLa41WznlSFMmb9CjYov9LG";
static String AccessTokenSecret = "tpRs2tLubcRc5PcbKb0KSJklDATdcBAT5bFRD9EoSQ";
Serial myPort;
Twitter twitter = new TwitterFactory().getInstance();
String currentMention = "";
String currentHash ="";
String currentTweet ="";
String hashlist ="";
int trigger = 0;
int tweetTrigger = 0;
  size(125, 125);
//  frameRate(10);
  background(0);
  println(Serial.list());
  String arduinoPort = Serial.list()[0];
  myPort = new Serial(this, arduinoPort, 9600);
  minim = new Minim(this);
  crowd = minim.loadSample("hallway-crowd.mp3",1026);
  crowd.mute();
  bird = minim.loadSample("Morning2.wav",1026);
  bird.mute();
  loginTwitter();
void loginTwitter() {
  twitter.setOAuthConsumer(OAuthConsumerKey, OAuthConsumerSecret);
  AccessToken accessToken = loadAccessToken();
  twitter.setOAuthAccessToken(accessToken);
private static AccessToken loadAccessToken() {
  return new AccessToken(AccessToken, AccessTokenSecret);
void draw() {
  background(0);
  if ( myPort.available() > 0) {  // If data is available,
    while ( myPort.available() > 0)  trigger = myPort.read();  //arduino-processing evening read speed
      println(trigger);
      if (trigger == 1) {
        crowd.trigger();
        crowd.unmute();
        crowd.mute();
  text("@tweet", 35, 65);
  getHash();
  getMention();
  getNewTweet();
  //frameRate(10);
  delay(10000); // wait 15 seconds to avoid Twitter Rate Limit
void getMention() {
  List mentions = null;
  try {
    mentions = twitter.getMentions();
  catch(TwitterException e) {
    println("Exception: " + e + "; statusCode: " + e.getStatusCode());
  Status status = (Status)mentions.get(0);
  String newMention = str(status.getId());
  if (currentMention.equals(newMention) == false){
    currentMention = newMention;
    println(status.getText()+", by @"+status.getUser().getScreenName());
    bird.trigger();
    bird.unmute();
    myPort.write('H');
    bird.mute();
    myPort.write('L');
void getHash() {
  String queryStr = "#grAAD";
  try {
    Query query = new Query(queryStr);
    query.setRpp(1); // Get 10 of the 100 search results
    QueryResult result = twitter.search(query);
    List<Tweet>tweets = result.getTweets();
    for (Tweet tweet: tweets) {
      hashlist = tweet.getText();
      String newHash = hashlist;
        if(currentHash.equals(newHash)==false) {
            currentHash = newHash;
            println("@" + tweet.getFromUser() + " - " + tweet.getText());
            myPort.write('H');
            bird.trigger();
            bird.unmute();
            bird.mute();
            myPort.write('L');
  }  catch (TwitterException e) {
    println("Search tweets: " + e);
void getNewTweet() {
  try {
    List statuses = twitter.getUserTimeline(new Paging(1,1));
    for(int i=0; i<statuses.size(); i++) {
      Status status = (Status)statuses.get(i);
      String newTweet = status.getText();
          if(currentTweet.equals(newTweet)==false) {
            currentTweet = newTweet;
            println(status.getUser().getName() + ": " + status.getText());
            myPort.write('H');
            bird.trigger();
            bird.unmute();
          bird.mute();
          myPort.write('L');
  } catch(TwitterException e) {
    println("Get timeline: " + e + " Status code: " + e.getStatusCode());
I’ve also tried an if else if:
if ( average < 30)
bBelow = true;
else if (val == ‘H’) {
bBelow = true;
bBelow = false;
with no success. :sleeping: :sleeping:
Please modify that post, select the code hit the # icon and save it.
You are only looking at the serial input in the setup() function, this gets executed once only on start up. I think you need to be looking at the serial input each time round the loop.
Now that's just silly. Thankyou thankyou thankyou for being my eyes and life saver Grumpy_Mike, I really could not see that. You've saved my poor laptops life, its been chugging on for days putting up with my nonsense.
