//code Cent0 by Github whit help Cattledog
// Import required libraries
//#include <Arduino.h> //
#include <ESP8266WiFi.h>
#include <ESPAsyncTCP.h>
#include "ESPAsyncWebServer.h"
// my code
#include <SoftwareSerial.h>
SoftwareSerial SSerial(2, 3);
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_SSD1306.h>
// SCL GPIO5
// SDA GPIO4
#define OLED_RESET 0 // GPIO0
Adafruit_SSD1306 display(OLED_RESET);
//int buffer[40];
int ProdI;
int VDc;
int VoltAc;
int Watt;
int VDC;
int Temp;
int WattHome;
const byte startMarker = 0x94;
const byte messageLength = 21; //18
byte receivedBytes[messageLength + 1]; //include start marker
boolean newData = false;
boolean newData2 = false;
static boolean recvInProgress = false;
// Set your access point network credentials
const char* ssid = "XXX";//ESP8266-Access-Point
const char* password = "XXX";//123456789
// Set your Static IP address
IPAddress local_IP(192, 168, 23, 40);
// Set your Gateway IP address
IPAddress gateway(192, 168, 23, 3);
IPAddress subnet(255, 255, 255, 0);
//IPAddress primaryDNS(8, 8, 8, 8); //optional
//IPAddress secondaryDNS(8, 8, 4, 4); //optional
//String WattHome
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
String readTemp() {
return String(WattHome);
String readHumi() {
return String(ProdI); // return String(bme.readHumidity());
String readdc() {
return String(VDc); // aggiunto;
String readPres() {
return String(VoltAc);
void setup(){
// Serial port for debugging purposes
Serial.begin(500000); // 115200
SSerial.begin(9600);
// tolto messo nel loop
// Setting the ESP as an access point
Serial.print("Setting AP (Access Point)…");
// Remove the password parameter, if you want the AP (Access Point) to be open
if (!WiFi.config(local_IP, gateway, subnet)) { // , primaryDNS, secondaryDNS
Serial.println("STA Failed to configure");
// Connect to Wi-Fi network with SSID and password
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
// Print local IP address and start web server
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
server.begin();
// WiFi.softAP(ssid, password);
// IPAddress IP = WiFi.softAPIP();
// Serial.print("AP IP address: ");
// Serial.println(IP);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3C (for the 64x48)
// init done
display.display();
delay(50);
recvBytesWithStartMarker();
delay(10);
showNewData();
delay(10);
if (newData2 == true)
collectData();
// printNewData();
displayNewData();
funzione();
void recvBytesWithStartMarker()
newData2 = false; // add for stable cycle loop LAST EDIT 17/12/2022
static int ndx = 0;
byte rc;
while (SSerial.available() > 0 && newData == false)
rc = SSerial.read();
if (recvInProgress == true)
receivedBytes[ndx] = rc;
// if (ndx == 8 and rc != 0x05)
// if ((ndx == 12 and rc != 0x04) and (ndx == 21 and rc != 0x34))
if (ndx == 21 and rc != 0x34)
//__________________________________________________________________________________
Serial.println("This just in false ");
for (byte i = 0; i <= messageLength; i++)
Serial.print(receivedBytes[i], HEX);
Serial.print(" ");
//____________
// newData = false; // aggiunto _________________________
ndx = 0;
ndx++;
if (ndx == messageLength + 1)
newData = true;
ndx = 0;
// else if (rc == startMarker || rc == 0x95 )
// else if ( rc == 0x95 )
else if ((rc == 0x94)|| (rc == 0x95) || (rc == 0x96) )
// else if ( rc == 0x94 || rc == 0x95 || rc == 0x96 || rc == 0x93 )
recvInProgress = true;
ndx = 0; // save start marker
ndx++;
// if (ndx == 1 and rc == 0x94 or rc == 0x95 && ndx == 13 and rc == 0x04)
// recvInProgress = false;
// Serial.println("This just in false ");
// for (byte i = 0; i <= messageLength; i++)
// Serial.print(receivedBytes[i], HEX);
// Serial.print(" ");
void showNewData()
// if ((newData == true) and (recvInProgress == true))
if (newData == true)
Serial.println("This just in ...OK ");
Serial.print(" "); // IN LINEA
Serial.println(" ");
newData = false;
newData2 = true;
void collectData()
VoltAc = ((receivedBytes[1]*256+receivedBytes[2])/10);
ProdI = ((receivedBytes[3]*256+receivedBytes[4])/10);
VDc = ((receivedBytes[5]*256+receivedBytes[6])/8);
Temp = ((receivedBytes[13]*256+receivedBytes[14])/24);
WattHome = (((int32_t)receivedBytes[15] << 24) |((int32_t)receivedBytes[16] <<16) |
((int32_t)receivedBytes[17] << 8 ) |(int32_t)receivedBytes[18])/10;
void printNewData()
Serial.println("_____________________");
Serial.print("|Voltaggio AC|= ");
// if (VoltAc > 200 && VoltAc < 260) {
Serial.print(VoltAc,DEC);
Serial.println(" V");
// Serial.println("_____________________");
Serial.println("|Produzione |");
Serial.print ("|Istantanea |= ");
// ProdI = ((receivedBytes[4]*256+receivedBytes[5])/10);
Serial.print(ProdI);
Serial.println(" W");
Serial.print("|Voltaggio DC|= ");
Serial.println(VDc);
// VDC = (receivedBytes[6]*256+receivedBytes[7]);
// Serial.println(VDC);
Serial.print("|Temperatura |= ");
Serial.print(Temp);
Serial.println("°C");
Serial.println("|Consumo |");
Serial.print ("|Istantaneo |= ");
// WattHome = ((receivedBytes[17]*256+receivedBytes[18])/10);
Serial.print(WattHome);
// Serial.println("This just in .please this work ??? please ? HOOOOOOOO.. ");
Serial.println("INVERTER LOG");
void displayNewData()
display.display(); // FA LAMPEGGIARE
//delay(50);
// Clear the buffer.
display.clearDisplay();
// text display tests
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(0,0);
display.print("Casa:" );
display.print(WattHome);
display.println("W" );
display.print("VAc :" );
display.print(VoltAc);
display.println("V" );
display.print("Temp:");
display.print(Temp);
display.println("C" );
display.print("VDc :");
display.print(VDc);
display.println("---------" );
display.print("Prod:");
display.print(ProdI);
void funzione()
server.on("/temperature", HTTP_GET, [](AsyncWebServerRequest *request){ //______________________
request->send_P(200, "text/plain", readTemp().c_str());
server.on("/humidity", HTTP_GET, [](AsyncWebServerRequest *request){ //___________________
request->send_P(200, "text/plain", readHumi().c_str());
server.on("/vdc", HTTP_GET, [](AsyncWebServerRequest *request){ //___________________
request->send_P(200, "text/plain", readdc().c_str());
server.on("/pressure", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", readPres().c_str()); //____________________
server.begin();
newData2 = false;
added video
