Hello,
i'm trying to send 433Mhz wifi codes using rcswitch lib.
when i enter the number from the remote control, the output is another number
so how can i convert the input to an integer that i can pass to the send function without overflow?
Largest number is around 9432208.
here is what i already tried:
  if (readString.length() > 0) {
   Serial.print("Input: ");
   //Serial.println(readString); //so you can see the captured string
   //int n = readString.toInt(); //convert readString into a number
   int intLength = readString.length() + 1;
   readString.toCharArray(intBuffer, intLength);
   int n = atoi(intBuffer);
   //int n = Integer.valueOf(readString);
   Serial.println(n); //so you can see the captured string
   mySwitch.send(n, 24);
   readString = "";
   delay(100);
