Serial read, Wait for $GPRMC [Solved!]
I have a GPS set to do nothing but the $GPRMC.
With this, I check for the $ and it blinks 13 once / sec ?
  Serial.begin(4800);
  pinMode(13, OUTPUT);
  if (Serial.available() > 0)
    int inByte = Serial.read();
    if (inByte == 36)
      dollarblink();
void dollarblink ()
  digitalWrite(13, HIGH);
  delay(100);
  digitalWrite(13, LOW);
So, for my follow-up, I wanted to test for the complete sentence header, but 13 stays on all the time (my scheme craters) ?
int i;
int GPSchar [13];
int GPScheck [7] = {36,71,80,82,77,67,44};
//                   $  G  P  R  M  C  ,
  Serial.begin(4800);
void loop()               // wait for $GPRMC,
  for (i = 0; i < 7; i++)
      GPSchar[i] = Serial.read();
      if (GPSchar[i] != GPScheck[i])
        checkbombed();
  successblink();
void checkbombed ()
  i = 0;    // re-initialise loop
void successblink()
  delay(75);
Do I need more/some delay between Serial.reads?
Once I verify that I've captured the header - $GPRMC, - I want to grab the next six characters/bytes [hhmmss].
*** Modify subject title ***
You may want to capture the data as a string like below and extract the desired info.
//zoomkat 3-5-12 simple delimited ',' string parce
//from serial port input (via serial monitor)
//and print result out serial port
// CR/LF could also be a delimiter
String readString;
  Serial.println("serial delimit test 1.0"); // so I can keep track of what is loaded
  //expect a string like wer,qwe rty,123 456,hyre kjhg,
  //or like hello world,who are you?,bye!,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      //do stuff
      Serial.println(readString); //prints string to serial port out
      readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
Thanks for your Reply, zoomkat.
OK
I have, what appears to be, a successful "Wait for $GPRMC".
I could test it more thoroughly, by enabling another sentence or sending it some manual input, but it's D13'ing 1pps.
int idx;
int GPSchar [13];
int GPSchk [7] = {36,71,80,82,77,67,44};
//                 $  G  P  R  M  C  ,
  Serial.begin(4800);
  while (idx < 7)
    if(Serial.available() > 0)
      GPSchar[idx] = Serial.read();
      if(GPSchar[idx] == GPSchk[idx])
        idx++;
        idx = 0;
  successblink();
void successblink()
  delay(75);
  for (int a=0; a<7; a++)
    GPSchar[a]=0;
  idx = 0;
I haven't captured the time characters yet, haven't tried ??? one step at a time.
OK
I've succeeded in capturing the time characters
