Serial read
Hello,
I would be very grateful if somebody could explain the following outcome of the serial communication.
I am using some global variables (datatype char and byte) to make decisions in the "loop" part of the code. The variables get modified over the serial input buffer, where I read 2 bytes and act accordingly (please see the code below)
while(Serial.available() > 1) { // wait for 2 bytes
      // prefix command
      prefix_command = (char) Serial.read();
      if(prefix_command == 'r') {
          command_r = (char) Serial.read();
      else if(prefix_command == 'f') {
          command_f = (char) Serial.read();
      else if(prefix_command == 'E') {
          eeprom_data = (byte) Serial.read();
      else Serial.println("ERROR");
If I open the serial monitor and send two bytes of data (ascii format), for example r0, the first "if" condition is met and the "command_r" is modified to '0'. This works for all modes and I have no problem here.
The question I have follows: If I send two bytes of data, the values get modified, but not before the "ERROR" is printed out. Why is this happening? It may be very obvious, but I really can't tell.
Also I will be trying to implement CRC checking for my data over the serial, sending ~100 bytes (so CRC-16 should be okay right?). Do you have any pointers about calculating the CRC checksum? Are there any tested (optimized) libraries that could be used with arduino (basically I have a custom board with Atmega 328p)?
Thank you very much and best regards, K
What is your line ending set to in the serial monitor? You may be sending a newline and/or a carriage-return as well.
Your method is not what I would recommend. Please read:
http://gammon.com.au/serial
Dear Mr. Gammon,
thank you very much for the answer. I will read the link you have provided with great interest.
Best regards, K
