Serial.readBytesUntil();
I would like to kinow whar is the code to read the serial until the enter key is pressed
here is my code:
while(!Serial.available()); byte choix = Serial.readBytesUntil('\n');
but i’ve got an error
Check Arduino documentation readBytesUntil(). This function returns an array not a byte
Alain46: Check Arduino documentation readBytesUntil(). This function returns an array not a byte
what should i had int the command
Serial.readBytesUntil(character, buffer, length)
You should read the documentation :
https://www.arduino.cc/en/Reference/StreamReadBytesUntil
 char buffer[16];
 int size = Serial.readBytesUntil('\n', buffer, 16);
 for (int i = 0 ; i < size ; i++) {
   Serial.println(buffer[i], HEX);
Hope it helps …
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data.
...R
