Serial.readString for multiple strings at once
I'm trying to control 2 things at once via a VB form, a set of servos and a motor. I watched Michael Reeve's tutorial on his laser turret and copied that, and I added the motor. I have the C# code sending serial data to the arduino, coordinates for the servos and a simple turn-on command for the motor. I'm having trouble having the arduino read both commands at once. I assume that the arduino cant read 2 different serial strings at once, but I'm not sure how to go about fixing this.
Here is the arduino code:
#include<Servo.h>
Servo servX;
Servo servY;
String serialData;
String serialDataFire;
 //initialize servos
 servX.attach(5);
 servY.attach(6);
 //initialize motor controller pins
 pinMode(8, OUTPUT); //IN3
 pinMode(9, OUTPUT); //IN4
 pinMode(10, OUTPUT);  //ENB/PWM
 //Begin Serial Communication
 Serial.setTimeout(10);  //shortens command delay apparently
 serialEventFire();
//  Servo Stuff
void serialEvent ()   //reads the data via serial connection
 serialData = Serial.readString();
 Serial.print(serialData);
 servX.write(parseDataX(serialData));
 servY.write(parseDataY(serialData));
// the data will be coming in as X100Y100 (for example). To use the data, we need to
// isolate the numbers, by removing all of the other characters:
int parseDataX(String data)
 data.remove(data.indexOf ("Y"));
 data.remove(data.indexOf ("X"), 1);
 return data.toInt();
int parseDataY(String data)
 data.remove(0, data.indexOf("Y") + 1);
//  Motor Controller Stuff
void serialEventFire()  //reads in the Fire comand via serial connection
 //reads in the string sent via serial
 serialDataFire = Serial.readString();
 //determines if serialData holds a string
 if (serialDataFire.equalsIgnoreCase("fire"))
   Fire();
 Serial.print(serialDataFire);
void Fire() //turns on the motors
 digitalWrite(8, HIGH);
 digitalWrite(9, LOW);
 analogWrite(10, 245);
 delay (4250);
 digitalWrite(8, LOW);
Here is the C# code
Quote
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.Diagnostics;
//IN PROGRESS COMBINATION
namespace WindowsFormsApplication2
    public partial class Form1 : Form
        public Stopwatch watch { get; set; }    //needed to slow the speed at which we send the arduino information for the servos, for latency
        public string fire = "Fire";
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
            watch = Stopwatch.StartNew();
            port.Open();
        private void Form1_MouseMove(object sender, MouseEventArgs e)
            writeToPort(new Point(e.X, e.Y));
        public void writeToPort(Point coordinates)
            if (watch.ElapsedMilliseconds > 15)     //sends arduino info every 15 milliseconds
                port.Write(String.Format("X{0}Y{1}",
                (180 - coordinates.X / (Size.Width / 180)),       //takes coordinates by the scale. Size of form (600) / max servo rotation (180)
                (180 - coordinates.Y / (Size.Height / 180))));
        private void Form1_Click(object sender, EventArgs e)
            port.Write(fire);
Please replace the quote tags by code tags in your previous post.
Read Serial Input Basics to handle serial input. Next you can adjust the C# code (if needed).
