int redPin=5;
int greenPin=6;
int bluePin=7;
String myColour;
String msg="Colour pls:";
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
Serial.println(msg);
while (Serial.available()==0) {
myColour = Serial.readString();
if (myColour=="red") {
digitalWrite(redPin, HIGH);
digitalWrite(greenPin, LOW);
digitalWrite(bluePin, LOW);
if (myColour=="green") {
digitalWrite(redPin, LOW);
digitalWrite(greenPin, HIGH);
if (myColour=="blue") {
digitalWrite(bluePin, HIGH);
}`Use code tags to format code for the forum`
not sure why but my Serial.readString() command is not working. The IDE shows no syntax mistakes, have tried different pins with the RGB Led as well as the 5V pin where everything is working individually yet once i try to use the if statements to input a colour, the LED doesn't light up.
