Greetings everyone, I want a program for which I want to receive serially for a particular amount of time and for the rest of the time it should not receive (if it is received and stored in buffer it should be discarded before entering the reception time).
in second code I feel I'm missing continuous reception.
can anyone write a code for continuous reception for a time of "internal" after which count has to be zero(count = 0)
It's not our practice to write code for poster because this gets abused too often by students who are too lazy to do their own homework and come here asking us to do it for them so they can go out and party. We know you are not one of those, right ? XD
We'll be happy to give you suggestions and point you to tutorials but asking us to write your code is crossing the line. We are here to help people learn , not to do their homework. I am sure you want to learn.
Are you sure you know what Serial.flush does? Here's a hint, it has to do with outgoing serial data and since you aren't sending any out you're only reading it doesn't do anything.
If you want to clear the serial buffer then read characters and throw them away until it is empty.
I also notice that you set count to 1 but never set it back to zero. Is that what you wanted to do? It will continually read after the interval passes once.
Please see this link, it says it waits for transmission to complete if we are sending any, and clears the buffered data came from other source.
If I'm wrong please enlighten me.
Yes, pardon me about it. =(
This is a part of a huge program which I'm working on based on Swarm robotics.
In my program the count will become zero at some point which is independent of "interval" so till then it must receive.
So i cant make count = 0.
Till count becomes equal to zero it has to receive.
Waits for the transmission of outgoing serial data to complete. (Prior to Arduino 1.0, this instead removed any buffered incoming serial data.)
Are you using an ancient version of the software? Otherwise all it does is block until all the data you sent out of arduino has been sent. Since you aren't sending anything it does nothing.
Well not specifically, but as pointed out the function of Serial.flush() is different. The question is WHY are you using 0023 ?
You answered with a question "WHY ?" so you didn't answer my question. Is there a reason why you are avoiding my question ?
