Serial selection
Relatively newbie sort of question. I am working with sending commands to servomotors using the serial library. It was easy sending commands to several servos when they all were told to go to the same position, but now I want to select which servo to write. I would use numbers to identify the servomotors, however that has conflicts with the servo position writing.
My question is: How can I use the serial monitor to select which servo to wrote? I was thinking using the obvious "if(...){...}" to select the servo using a command from the serial. Any suggestions? I may be circling the solution here but missing it as I'm not quite familiar yet with serial library...
It's easier to help you with a solution if we actually saw what you're working with.
Sorry to say but I have complications with entering the forum on my computer. It works only occasionally and I cannot diagnose the problem. I have to resort to utilizing my mobile. I will work on it later. I'll respond when I have the sketch. Its strange... I have absolutely no problems on any other address except for a few lying within the arduino site. But that's a problem for another day. I should have it up soon though
Code for controlling several servos
//zoomkat 11-22-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod;  // create servo object to control a servo
  //myservoa.writeMicroseconds(1500); //set initial servo position if desired
  myservoa.attach(6);  //the pin for the servoa control
  myservob.attach(7);  //the pin for the servob control
  myservoc.attach(8);  //the pin for the servoc control
  myservod.attach(9);  //the pin for the servod control
  Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
  //expect single strings like 700a, or 1500c, or 2000d,
  //or like 30c, or 90a, or 180d,
  //or combined like 30c,180b,70a,120d,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      if (readString.length() >1) {
        Serial.println(readString); //prints string to serial port out
        int n = readString.toInt();  //convert readString into a number
        // auto select appropriate value, copied from someone elses code.
        if(n >= 500)
          Serial.print("writing Microseconds: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
          if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
          if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
          if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
          Serial.print("writing Angle: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.write(n);
          if(readString.indexOf('b') >0) myservob.write(n);
          if(readString.indexOf('c') >0) myservoc.write(n);
          if(readString.indexOf('d') >0) myservod.write(n);
         readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
