As a newbie, this started out an exercise to send serial using lowByte, highByte in the program questions forum but on the good advice of others and guidance from Robin2's excellent 'Serial Input Basics', resulted in an exercise to generate send and receive serial with Char buffers and convert from and to an Int
Robin2's post is great to understand the receive end but I was getting stuck with the send end. So I experimented and had good results so I thought I would post this to hopefully help others
After lots of playing I have a system that seems to work although the receive is a bit unstable if Serial.prints are used in the sketch (not sure why yet).
Send code is;
#include <string.h>
char sentchar[7];
int rpm = 12341;//test variable to send
char endbuff [2];
char startbuff [8];//plus null plus end marker plus start marker
char endmarker = '>';
char startmarker = '<';
memset(startbuff, 0x00, 8);
memset(endbuff, 0x00, 2);
memset(startbuff, 0x00, 2);
endbuff[0] = endmarker;
startbuff[0] = startmarker;
itoa (rpm, sentchar, 10);
strcat(sentchar, endbuff);
strcat(startbuff, sentchar);
Serial.write (startbuff);//reports <12341> on serial monitor
Receive code is;
//Receive with an start and end-marker
#include <string.h>
const byte numBin = 6;//do not write start and end markers
char receivedBin[numBin];
boolean newData = false;
Serial.begin(9600);//on Nano
Serial1.begin(9600);//on Mega
Serial.println("<Arduino is ready>");
recvWithStartEndMarker();
showNewData();
void recvWithStartEndMarker() {
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '>';
char rc;
while (Serial1.available() > 0 && newData == false) {
rc = Serial1.read();
if (recvInProgress == true) {
if (rc != endMarker) {
Serial.println("no endMarker");
receivedBin[ndx] = rc;//keep populating the array until the end marker is found
ndx++;
if (ndx >= numBin) {//if last segment in array is found
ndx = numBin - 1;// move marker to position 5
else {
Serial.println("endMarker found");
receivedBin[ndx] = '\0'; // if end marker is found then terminate
ndx = 0;//reset array position
newData = true;
else if (rc == startMarker) {
recvInProgress = true;
rpm = atoi(receivedBin);//convert back to Int
Serial.println (rpm);
void showNewData() {
if (newData == true) {//if array is polulated with good data
Serial.println("This just in ...should report 12341 ");
Serial.println(receivedBin[0]);
Serial.println(receivedBin[1]);
Serial.println(receivedBin[2]);
Serial.println(receivedBin[3]);
Serial.println(receivedBin[4]);
Serial.println(receivedBin[5]);
newData = false;
Hopefully I have understood everything correctly. The comms seems stable.
Why not use my recvWithStartEndMarkers() without any modifications? After all, you are just sending text.
The lines
should not be in recvWithStartEndMarkers() as they are for parsing the data rather than for receiving it. Restricting the work of a function to a single task makes program development and debugging much easier.
Of course you are right, Brain fart when I posted that.
Still, learnt some more stuff all be it probably not best deployed.....
Can you please explain what you mean by....
You have reduced Robin's code to something that now can only handle integers.
See, the idea is that the receive function just does that, receive. Printing is not part of receive, neither is conversion.
Think in layers
[size=small]
| use processed data |
| process recv'd data |
| receive data |
[/size]
I just saw the error in my send. I was using "<" instead of '<'.
The send looks good on the serial monitor but the receive still isnt right and misses characters (I am not trying to convert back to Int yet on receive, it is just your code).
const byte numChars = 32;
char receivedChars[numChars];//receive char version
//byte receivedChars[numChars];//receive byte version
recvWithStartEndMarkers();
showNewData();
void recvWithStartEndMarkers() {
char rc;//receive char version
// byte rc;//receive byte version
// if (Serial.available() > 0) {
Serial.println (rc);
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
Serial.print("This just in ... ");
Serial.println(receivedChars);// char version
// Serial.println((char*)receivedChars);//byte version
newData = false;
Serial monitor is;
This just in ... 12341
This just in ... 12347
This just in ... 123412341
This just in ... 1341
This just in ... 141
This just in ... 1231
This just in ... 1234a
This just in ... 12341<12341
This just in ... 11
This just in ... 1234123412341
This just in ... 41
This just in ... 123<12341
This just in ... 123341
This just in ... 41
This just in ... 41
This just in ... 11
This just in ... 11
This just in ... 12
This just in ... 12
This just in ... 12
This just in ... 12
Could it just be line noise?
I have very short wires (jumpers) and everything is powered from PC USB. Just a nano and mega connected (5v, 0v, Tx/Rx) with no other wires or code going on.
You're continously pumping data from the transmitter (7 bytes); it's the only thing the transmitter has to do so is 'fast'.
The receiver receives this in a 64 byte buffer from where you read it using Serial.read(); however, the receiver has more to do like keeping track of the index, checking for startmarker and endmarker and other stuff in your code; that takes a little more time and as a result it can e.g. only process 6 bytes of the 7 and 1 is still in the buffer when the next bunch of 7 arrives (so you now have eight bytes). Eventually the 64 byte buffer fills up and when another character arrives, it's simply discarded.
The delay prevents that you continously pump data and gives the receiver time to catch up. At 9600 baud, one character takes rougly 1 millisecond to transmit, so 100 milliseconds delay is more than likely overkill (trial and error to find a reasonable value).
Under normal situations, the transmitter will only send something when it has to; e.g. after reading an analog input (this takes about 100 milliseconds) or when a button becomes pressed (this can take anywhere from N milliseconds to hours).
If you really need to send data as fast as possible, you will need to implement a protocol where the receiver tells the transmitter when it can send. E.g. after the receiver has received and processed the information, it can send a single byte back to the transmitter. The transmitter will wait for this byte before sending the next bunch of data. It involves a little more but this should give you the idea.
int rpm_val;
showNewData();
rpm_val = atoi(receivedChars);
Serial.print("Converted back to RPM ");
Serial.println(rpm_val);
//Serial.println (rc);
ndx++;
ndx = numChars - 1;
else {
ndx = 0;
newData = true;
newData = false;
Output is;
Converted back to RPM 12341
Obviously missed something somewhere. I thought I needed to place rpm in a character array (with a space for a null) and in doing so needed ITOA? It was suggested in one of Robin2's, but I probably mis understood the concept.
But as you say the print class sends the characters of the integer anyway. What about the terminator?
I tested it by just running Serial.print (rpm); and I seem to get more received errors.
My next problem is that the Mega code has so much going on that the reporting of RPM is very slow and by the time it gets round to noticing a change at the receive end display its probably 20 seconds before the receive buffer empties after stopping the send from the nano.
kpg:
My next problem is that the Mega code has so much going on that the reporting of RPM is very slow and by the time it gets round to noticing a change at the receive end display its probably 20 seconds behind the send end from the nano.
