Serial Sketch Works On UNO And Not The MEGA
-Hi
This is my first post because I usually take the time and fix the problem myself but I've tried many different variations of this code and have had no luck. Here is my problem:
I'm working on a serial communication protical and have been doing a good amount of testing on my UNO I use for code development. However when I try to run the same code on the MEGA this sketch does not work. Basically the sketch reads in serial data, an unsigned integer, and lights up a pin if the throttle and yaw parameters are above a threshold (I've tried multiple pins so this isn't the problem in this particular sketch). The data from the sender (I've tried many external sources but current am using Simulink) runs at 50ms and the main code runs at about 10ms. The data from the sender is 8 unsigned integers, that's why bitsIn is set to 16. I've tried using a ttl to usb converter on this sketch and used the MEGA's other serial pins so I can monitor what I'm actually receiving but I'm receiving garbage. Here is the code, could you tell me why this works on the UNO and not the MEGA?
int ledPin = 8; // the pin that the LED is attached to
int bitsIn =16; //Amount of expected bitsIn
int incomingByte[16];    //bitsIn
unsigned int number[8]; //array to store integers bytes in devided by 2
///Loop initializers
int i=0;
int a=0;
int b=0;
  // initialize serial communication:
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // see if there's enough incoming serial data:
  if (Serial.available() >= bitsIn) {
      // read in all expected bytes
      while ( i <= (bitsIn -1) ) {
      incomingByte[i] = Serial.read();
      i=i+1;
      i=0;
      //Convert bytes to unsigned integers
      while(a <= (bitsIn /2-1)){
      number[a] = incomingByte[b+1]*256 +incomingByte[b];
//      Serial.print(number[a]);
      a=a+1;
      b=b+2;
      a=0;
      b=0;
      //Assign Numbers to actual variable names
      int throttle = number[1];//0-10,000
      float yaw = (float)number[2];//1,000-2,000
      float pitch = (float)number[3];//1,000-2,000
      float roll = (float)number[4];//1,000-2,000
      float yawmapped = map(yaw,1000,2000,-150,150);
///See if the header and footer where received as expected
      if (number[0] == 15642 && number[6] == 29874) {
        //light up an LED for throttle and yaw cases
            if(throttle >= 1500 || yawmapped >= 45.55){
            digitalWrite(ledPin, HIGH);
           else if (throttle < 1100) {
            digitalWrite(ledPin, LOW);
      //Clear remaining bytes on buffer, this will also fix any initial asynchronous reads to start off
      while(Serial.available()>0){
        Serial.read();
  ///Delay to allow more bytes to come in
  delay(10);
Also another note, when I use SoftwareSerial on the UNO the incoming data is no longer parsed correctly. The data I intend to receive is this (8 integers):
15642 1000 1500 1499 1499 1000 1000
What I'm getting after parsing the data and using the MEGA or software serial library is this (I've included a few loops worth of data below):
8261 20294 20053 8516 32 20302 8270 17735
21838 20041 8261 17732 18774 17731 17952 21839
17486 8225 19968 20047 18208 20037 18773 17742
17440 22085 17225 8261 20294 20053 8516 32
20302 8270 17735 21838 20041 8261 17732 18774
17731 17952 21839 17486 8225 19968 20047 18208
20037 18773 17742 17440 22085 17225 8261 20294
20053 8516 32 20302 8270 17735 21838 20041
8261 17732 18774 17731 17952 21839 17486 8225
19968 20047 18208 20037 18773 17742 17440 22085
17225 8261 20294 20053 8516 32 20302 8270
17735 21838 20041 8261 17732 18774 17731 17952
