Hou can I the serial string to ‘TX’ reroute to I2C lcd?
Please give more details of what you are tying to do, including posting your current sketch, using code tags when you do
It’s adafruit i2c soil sensor, soil the result must go to I2C lcd.
On Arduino Uno.
What have you tried so far ?
store it in an integer and use the function display.print(); with in the brackets the variable. You can add some text with the same function if you want. Just put it between "".
instead of printing to serial, print the value to the LCD
It’s fixed, I must open my view.
Thanks
I don't know what you mean by that, but I am glad that you got it working
Het is nu ok,
ik moest met een nieuwe blik kijken.
Dank je.
That makes more sense !
No problem, everybody can get stuck because they don't see the solution anymore.
