Serial & strings
Hi!!
Im making some tests using LabView, its really easy to interface with it, but a have some problems:
  • If i send from labview and a dial (0-255) valors, the problem is that it will be send one character at the time.... how can i receive a string of more than 2 characters in the serial port?
i try this:
a = Serial.read();
b = Serial.read();
c = Serial.read();
Serial.print("Se recibio: ");
Serial.print(a);
Serial.print(b);
Serial.println(c);
For receiving 3 characters, but i only get this on the monitor:
Se recibio: 1ÿÿ
Se recibio: 23ÿ
and o would like to receive:
123
jejejeje
can it be done?
how could i do it?
10x!!
cheers!!
you must check to see if characters are available for reading (with Serial.available()). Otherwise, Serial.read() will return garbage (which is exactly what you are seeing).
e.g.
while (Serial.available() < 1 )
a=Serial.read();
b=Serial.read();
-j
Thanks!!!
It works!!
my code finish like this:
arr[0]=Serial.read();
arr[1]=Serial.read();
arr[2]=Serial.read();
Serial.print(arr[0],BYTE);
Serial.print(arr[1],BYTE);
Serial.println(arr[2],BYTE);
arr[0]=arr[0]-48;
arr[1]=arr[1]-48;
arr[2]=arr[2]-48;
cad=(arr[0]*100)+(arr[1]*10)+arr[2];
//Serial.println(cad);
if(cad<256)
if(cad>0)
convertir(cad);
convertir(0);
convertir(0);
Serial.flush();
10x!!!
Cheers!!!
Of course you could do:-
while (Serial.available() < 3 )
Right, which is what I proposed in the other incarnation of this thread. Grr.. :slight_smile:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1226197859/1#1
