I'm not really sure what I need; I'm not familiar with the terminology and the animations I've seen don't help.
Basically, I want to drive LEDs; I can use transistors as a switch if I need to, and I already know how to do this.
Here's the part I'm stuck on:
I need to be able to send serial data and have it come out as parallel data, hence the need for a serial-to-parallel device. I think it has to be some sort of shift register, but I'm not sure. My issue is that I don't want the outputs (the parallel pins) of the serial-to-parallel converter to change as I'm sending the serial data into it. Also, I don't want the parallel pins to change from their previous state until the data is written to them.
So basically, I need to be able to give it the data via serial, but whenever it updates the parallel pins, it updates them all simultaneously, rather than "as the data comes in".
This is standard in most shift registers, because you are not the only one who likes this. The most popular device is called 74595 (or 74HC595); I have seen 5 projects during the last three days using this. There are also tutorials..
MAX7219 are also heplfull, each one will drive 64 LED's and they can be chained to drive more, also 8x8 LED matrixes and 8 digit 7segment displays, and any combination of the above!
I am running 4 driving 2x 8x8 matrixes and 4x 4 digit 7segment displays, and the libraries are very simple to understand!
I figured there wasn't anything to worry about, but I'm still very new to the IC interfacing field. Also, I found the tutorial using the chips deSilva mentioned: http://www.arduino.cc/en/Tutorial/ShiftOut
I knew that it would send the data "all at once", but I didn't know if "the data" meant "a pulse", or if it included "stay on until the data tells you to go off".
I guess it includes that, too..
(Sorry for my slow response to your replies; I've had limited Internet access lately.)
