I connected an HC-06(bluetooth module)'s TX pin to a relay's IN pin. What serial signal do I send to the HC-06 to turn the relay on/off? Thanks!
You are going to need an Arduino between the HC-06 and the relay
Thanks! I thought it was theoretically possible to so.
"Thanks! I thought it was theoretically possible to so."
A data sheet might be the thing to check for the HC-06 capabilities.
