Serial Trouble
Hi
I am having same strange issue, this issue appears on Arduino Mega family and code works fine with hardware serial on Leonardo.
I am posting simple code to reproduce the issue. Connecting any Serial device on Serial1 (I tested with SIM808) Sim800.
  while(!Serial);
  Serial1.begin(115200);
  while(Serial.available())
    Serial1.write(Serial.read());
  while(Serial1.available())
    Serial.write(Serial1.read());
Sending AT with echo enabled on GSM should output
AT <---- Coming to Arduino
OK <----
but it outputs
AT <---- This is data which was transmitted on TX but it is recieved on RX as well, (THIS IS ISSUE!)
OK <----
Also check other ports as well, same issue.
Same issue posted by someone else.
Funny. I happen to have a test running just now, that has been running all week, with all four ports streaming at 1Mbps - no problems.
@mechatronicsengr, please do not hijack. Thread split.
Just for the record, I don't think this was a case of hijack - simply inexperience leading to re-awakening of a very old Thread.
...R
