I’ve hooked up a sim800 gsm modem on an UNO (pin 0, 1). I wrote a simple sketch which sends 2 modem commands over the serial connection. First setup a call, delay 5 seconds and then disconnect the call. When I upload the sketch from the arduino ide everything works fine (tx is lid, modem receives commands and initiates/ends the call).
When I power cycle the arduino and modem the sketch is started again (blink check ok) but the serial transmission is not initiated. No AT commands send (tx not lid). Also tried with external power, same result no serial transmission. What could be the cause of this problem.
What happens if you just reset the Uno, with the reset button, without cycling the power? Can you, please, post your code? Please read the "how to use the forum-please read" stickies to see how to format and post code.
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Here is the code, it works fine after an upload from the Arduino IDE. But with both powercycle and reset debug flash works but no tx led flashes. (also tried external power 9v 1A no tx either)
I stripped my original sketch to eliminate other interference. There is no need for libs or vars in this simple example.
I tried #5, same effect; immediately after sketch upload it is working fine. But when power cycle, reset or external power is used the AT commands are not send. Only when the sketch is uploaded again it works. Could it be something which configured/set on the serial port by the uploading sequence?
You do not need to upload code again. We here this from beginners many times and they are always mistaken.
Yes their is as your code as posted will not compile, so how can we try it?
As you choose not to cooperate with simple requests I guess you are in your own.
