Hi everyone! I am trying to setup a system where I have to hit # that will make the status wait and recieve all the data in a function. Save it all as a String, then when I hit # again, it leaves the function. With the code provided below, I am able to do it, Expect it looks like the data is garbage and looping into itself. Can anyone help me?
#include <OneWire.h>
#include "pitches.h"
String keylinkData = "";
int serialCommand;
OneWire reader(12);
Serial.begin(9600);}
void checkStatus(){ byte addr[8]; reader.reset_search();
if (!reader.search(addr)) {reader.reset_search(); return; }
else{iButton(); } }
boolean array_cmp(int *a, int *b, int len_a, int len_b){
if (len_a != len_b) return false; return true;}
void iButton(){
byte i;
byte addr[8];
byte addr2[8];
int arr_a[] = {addr[8]};
int arr_b[] = {addr2[8]};
while(reader.search(addr)) {
for( i = 7; i > 0; i--) {
if (addr[i] < 16) {
Serial.print('0'); }
if ( addr[2] + addr[6] + addr[5] + addr[4] + addr[3] == 00) {return;}
Serial.print(addr[i] , HEX);
if (addr[0] < 2 ) { Serial.print("0"); Serial.print(addr[0], HEX); }
else { Serial.print(addr[0], HEX); }
tone(8, NOTE_DS8, 200);
Serial.println(" "); delay(1000); }
while(reader.search(addr2)){
if (array_cmp(arr_a, arr_b, 7, 7) == true){delay(2000); } }
char serialCheck(){
if (Serial.available())
byte serialCommand = Serial.read();
if (serialCommand==35)
while ((char)Serial.read() != '#' ) {
char inChar = (char)Serial.read();
keylinkData += inChar;
Serial.println(keylinkData);
checkStatus();
serialCheck();
Serial.println("Back to loop");
delay(10);
That will also create the issue. My best guess is that it is looking at its own return and adding it to the value of inChar but I have no idea how to fix this...
Simple serial code examples that check for the presence of characters in the incoming serial buffer.
// zoomkat 7-30-11 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
String readString;
Serial.println("serial test 0021"); // so I can keep track of what is loaded
while (Serial.available()) {
delay(2); //delay to allow byte to arrive in input buffer
char c = Serial.read();
readString += c;
if (readString.length() >0) {
Serial.println(readString);
readString="";
//zoomkat 3-5-12 simple delimited ',' string
//from serial port input (via serial monitor)
//and print result out serial port
String readString;
Serial.println("serial delimit test 1.0"); // so I can keep track of what is loaded
//expect a string like wer,qwe rty,123 456,hyre kjhg,
//or like hello world,who are you?,bye!,
if (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
if (c == ',') {
//do stuff
Serial.println(readString); //prints string to serial port out
readString=""; //clears variable for new input
else {
readString += c; //makes the string readString
In the first program I showed, How can I hit a key lets say # (which works on the pgroam) then WAIT and anything comes through is going to the String, then hit # again and get out of that loop?
brolly759:
Perhaps you should give a technical explanation of "hit a key lets say #". Are you hitting a key on a pc and sending that character to the arduino via serial? There is sample serial code available with different start and stop data delimiting characters. You chose to use the same character, so you would probably need to set a flag in your code that toggled each time a # is received.
Here is what I changed to make it work. I do have another question though. I know the string is loaded in SRam. It is static memory and goes away, but my question is, how long will it stay there? Until I shut off the device? Every time I close the serial terminal and open it, the value disappears even if I do not shut down the device.... What am I doing wrong?
You don't understand your arduino. Opening/closing the serial monitor (or terminal application that toggles DTR) will cause the arduino to reset. You can defeat the reset using a ~100 ohm resistor between the arduino 5v pin and the reset pin, or a large capacitor between the reset pin and ground.
I added a 220ohm resistor and that worked like a charm. Did not have a 100ohm on hand. You are right, I don't know my arduino. I know the basics and as much as I read information on these devices, I learn better if I have a goal. Each obstacle I run into helps me learn more and more by applying the fixes and figuring out work arounds to my mistakes.
Is there any reason to ever have DTR enabled to restart the arduino?
