Serial window with ATtiny45/85 and library ATTinyCore
Hallo,
the target is, I would like to switch on/off an ATtiny45 over an LDR on PIN2.
To see how the LDR works I would test the serial communication with an ATtiny45. The connection to the ATtiny45 from Uno to ATtiny works and I can upload Test Sketches with LEDs on PIN 0,1,3 and 4.
For my serial connection test I use the information from this video "ATTINY-85 Serial Monitor. Step-by-step Arduino IDE Guide" ATTINY-85 Serial Monitor. Step-by-step Arduino IDE Guide - YouTube. All about ATtiny85 I changed in the AdruinoIDE to Tttiny45.
I have used the instructions on the end of the video and used this mentioned sketch from the author:
Tom Donnelly on YouTube: "ATTINY-85 Serial Monitor. Step-by-step Arduino IDE Guide":
"#include <SoftwareSerial.h>
SoftwareSerial Monitor(5, 4);
Monitor.begin(9600);
pinMode(0, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, INPUT);
digitalWrite(0, HIGH);
Monitor.println("LED on");
digitalWrite(0, LOW);
Monitor.println("LED off");
On Adruino Uno the LED for Tx is blinking - RX is off
PIN3 (analog) is connected with RX on Uno
PIN4 (analog) is connected with TX on Uno
The message is this:
Der Sketch verwendet 2170 Bytes (52%) des Programmspeicherplatzes. Das Maximum sind 4096 Bytes.
Globale Variablen verwenden 140 Bytes (54%) des dynamischen Speichers, 116 Bytes für lokale Variablen verbleiben. Das Maximum sind 256 Bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Who has any idea why the sketch is not upload?
Thanks for help
Mike
